- First Name
- David
- Sep 18, 2022
- California
- 2023 Maverick XLT, 2014 MX5 Club
- Engine
- 2.5L Hybrid
As can be seen by the pictures, the back corners hang out the back corners quite a bit. I'm not sure that I have a front of the bed (back window) completely sealed as the clips to hold the cover when folded are in the way and prevent the front seal from completely making contact with the rail. The clips would not be an issue if the bed was not connected to the cab - one of the flaws with uni-body construction.
The clips that hold the cover down are a bit of a pain to use, but I understood that when I bought the cover and I don't need to access the bed on a daily basis - if I did, this would be a deal breaker as you have to undo each section from the right side and then the left (or vice versa). That is two clips for each section.
The installation was straight forward - only issue was the front clamps needed to be forced past the threads in order to get them to work correctly.
I don't know if it is "waterproof" as advertised -- I'll follow up on this review later. If it is, then it is worth the value price (under $500 on Amazon) https://www.amazon.com/dp/B0BHVYB6HM?psc=1&ref=ppx_yo2ov_dt_b_product_details compared to other covers for the Maverick being offered at this time.
