Lobo intercooler upgrade
Badluckinc
Indiana
2025 Lobo
Run into a big issue with upgrading the intercooler. Ford moved the adaptive cruise control radar from the upper grill to the lower. It is attached to the plastic that has to be removed to install the cvf intercooler. Probably going to have to make up some custom brackets to reattach it.
Ford Maverick Lobo intercooler upgrade 20250330_094430
Ford Maverick Lobo intercooler upgrade 20250330_094421
Lariat is there too, but the Tremor is in the upper grille. I would check out the Tremor grille and brackets to see if that's any use.
Badluckinc
Badluckinc
Indiana
2025 Lobo
I sent cvf an email letting them know the issue. See what they have to say or recommend. Will update once I have more information.
MosesP
San Antonio
Lobo
it sucks because on the base Lobo all of this is still there with the exception of the radar. 🤣
yeah.
I personally wouldn't do this at all - evidenced by the fact I haven't on my '22- but I respect and appreciate first movers as they help everyone. there is limited value you can get from any modifications until reflash tuning devices support the '25.
I still haven't seen anyone talk about a racechip/panda device or jb4 and surely those could be made compatible.
MosesP
San Antonio
Lobo
might have to buy the tremor grill and bracket to make it work. At least the sensors are the same between the 2 models.
Badluckinc
Badluckinc
Indiana
2025 Lobo
If it comes down to it, I'll just fab up a new mount for the radar that will put it in the same location.
something probably could be done with 3d printing, but I certainly don't have the expertise or tools to do that myself. I like the Tremor grille anyway, that's why I'd previously already looked into this.
fstlan3
Lauderdale
Escape
yeah.
I spoke to Burger about the JB4 and sent specs and pictures of the new engine and they said everything should work the same
TORQUERULES
Ford
Let's hope for your sake that the intercooler piping connections remain the same with the new MPC Ecoboost. Lots of changes to the routing, etc. in other applications with the new engine.
Badluckinc
Badluckinc
Indiana
2025 Lobo
Ford list the same part number for the 24 and 25 intercooler, so the connections "should" be the same.
agreed. downpipe is the same also, for the non GPF version at least. the up pipe might be different which is impactful for some mods, but not an intercooler swap.
TORQUERULES
Ford
That's good. Good luck! I got mine in fine, but it does take some finagleing.
there's a guy over in the big ACC DIY thread who designed a radar mount for the grille. it looks like it clamps on.
if you haven't a solution yet you might check that out.
