Livernois Question
Marjammer
Jack
Beavercreek, Ohio
'23 Atlas Blue Lariat Tremor
I was adjusting the brightness on my Livernois tuner and the entire screen suddenly went all black. I unplugged it and plugged it back in and the loading screen comes on. As soon as it is done booting up, it goes back to black screen. Anyone had this issue and know how to fix it?
colinl
Colin
ICT
No, I have never used a Livernois. Did you call or email them yet? That would be my first move, after Googling for it.
Bwicka
Lakeside,ca.
Call them thise guys are easy to work with and very helpfull , just got to make time during the work day.
AlpineKid74
Graham
Gaylord, MI
2025 Maverick XLT
Just curious, did you get this problem fixed?
Marjammer
Marjammer
Jack
Beavercreek, Ohio
I still have to call them. Just been busy.
budpalumbo
ohio
many
You put it on "1" the screen is basically black. I had to use my led tactical light to be able to see anything on it.
Just plug it in, let it sit at least a couple minutes to fully boot up. "settings" is the very bottom of the screen. The top of "brightness" is aligned with the bottom of the point where the ethernet cable goes in. Tap halfway down on the far left of the screen, better off low than higher from center but not too far or you won't hit a number and you should be able to see it again.
