- First Name
- Jim
- Sep 22, 2021
- Goddard, KS
- 2011 Nissan Frontier
Since the Lariat comes with 1" bigger wheels, will it have a 1" higher ground clearance?
I don't think that's the case. I think the tire size is the same. So, one inch bigger rims, one inch smaller sidewalls.Since the Lariat comes with 1" bigger wheels, will it have a 1" higher ground clearance?
I thought before that it was 8.2" for FWD models and 8.6" for AWD models, but turns out its 8.6" only with the optional FX4 wheel package.
[/QUOTE
That's what I thought to. Where did you see that only the FX4 had more ground clearance?
So is shorter sidewalls a bad thing?No. The tires for the 18" wheels are lower aspect ratio so shorter sidewalls. The 225/60R18 comes out to nominally a whole .05 inch taller.
Shorter sidewalls ride a bit stiffer and increase the risk of wheel damage from hitting potholes/obstructions. The performance advantage being less flex under cornering forces. Otherwise larger wheels and slimmer tires is regarded as looking sportier or fancier.So is shorter sidewalls a bad thing?
It'll give improved cornering feel due to less sidewall flex, but you also have an increased chance of damaging a wheel from a pothole or something since there's less tire sidewall to cushion any hits. And the NVH (noise, vibration harshness) will probably be marginally worse for the same reason. You could also curb-rash the wheels easier.So is shorter sidewalls a bad thing?
Many like the looks of larger wheels with less sidewall, and also the sharper/sportier handling, but at the cost of sometimes a rougher ride. Those that go a bit off-road/rough-road often like smaller wheels with larger tires (more rubber sidewall). Some people also like the smoother more-cushioned ride.So is shorter sidewalls a bad thing?
I think the 0.4" taller is because of 235 instead of 225 tire size although I would expect it would be a push for 235. Does FX4 come with 245's. Also expect some if not all difference would be in suspension!I thought before that it was 8.2" for FWD models and 8.6" for AWD models, but turns out its 8.6" only with the optional FX4 wheel package.
Here is a fun tool for you to play with.Apologies.. but not only am I complete truck newb, but I am a tire newb too.
