- Dec 3, 2021
- Cincinnati, OH
- '20 Ford Escape Titanium Hybrid 16 Ford Escape SE
- Engine
- 2.0L EcoBoost
Got around to installing the Kicker Key 200.4 and the pre made harness from plug & play kits. I will say that combined with the Morel 6.5 coax speakers I replaced the factory door speakers with is very impressive. A massive improvement over the rather weak XLT stock sound. The auto DSP setup with the mic thats included works well. I put the pink noise file on a USB stick and it does its thing within about a minute or two and is all setup. Couldn't be any easier and dummy proof which is good for me.
Install is super easy. Just pop off the panel that houses the HVAC controls and center vents and unplug the harness on the bottom right of the audio module (whatever it's called). Feed the harness through and mount the little amplifier somewhere behind the glovebox area. I'm waiting on getting one of the 3d printed mounts but for now I just used some velcro strips and put it on the top of the HVAC box. Fits pretty nicely there for now. I added some rubber stripping along the metal bracket edgeI had to run the harness around to avoid any future chafing on the wire harness. You will know what I'm talking about if you get in there and take a look.
If anyone has a better way to route that harness around or above that metal bracket I'm open to suggestions..
Also I'm going to play with the dip switch settings on the amp to see what happens. Right now it seems to have a center front stage biased sound that does sound really good but I would like a little more coming from the rear speakers just to even it out a little. Again, any suggestions are welcome.
Overall Id say the bang for the buck is a 10. I wasn't looking for big bass like with a sub just a much needed sound quality and volume improvement over the stock and this definitely delivers.
