I have the eco with fx4. Does eco mode really make a difference? I have the cable to enable with forscan but just want to make sure it’s worth it. Thanks
Have you noticed any difference in engine RPM between eco and normal mode, while at a steady cruise speed of 65 to 70 MPH?I have a FX4 and used Forscan last year to add sport and eco modes to mine.
It’s definitely worth adding eco in my opinion. It takes a bit of the initial throttle tip in twitchiness out and smooths out throttle response. Makes some in slow town driving a bit easier and I like it on long highway drives especially in the rain where I don’t need the aggressiveness that normal mode tends to have on the throttle at times.
I think it gained me maybe an extra MPG as well.
The only time I would not recommend eco mode is in aggressive traffic. There is a bit of lag from a start and if you were driving in normal and then went to eco, the person behind you might not expect it. It’s that noticeable of a difference.
Also, add sport mode while you are at it. I don’t use it much because I have a fast car for a daily and I tend to drive the Maverick easy in comparison to that but if you need quick acceleration and shifting for a tough situation or even for fun, it’s worth it. I can say I don’t like sport mode on the highway because it holds gears for too long when passing in my opinion but off-highway, it scoots for sure.
That I have not paid attention to for eco mode in particular but I’ll take a look as I have a highway trip coming up this weekend. Also for cruise control, it’s more relaxed in eco mode to maintain speed but at times on steep grades may be a bit lazy.Have you noticed any difference in engine RPM between eco and normal mode, while at a steady cruise speed of 65 to 70 MPH?
Ok well I will give it a try. ThanksI have a FX4 and used Forscan last year to add sport and eco modes to mine.
