yakefu
LA
XLT
I’m getting a Line-X SIBL done on Tuesday. My options are $450 for regular or $550 for UV protection. Do you know which product you got?
I think mine is just the regular one.
yakefu
LA
XLT
DangerZone
Arizona
XLT hybrid Maverick
Cause I dropped the Lux package, I have to find a place to do the SIBL. I got one shop recommended by a forum member(Frank, thank you). The Line-X shop is 30 mins from my home. And I got it done this morning. I'm very satisfied with the result. They cover most of the bed, even under the rear windows.
Nice job. I got color matched line-X on my Oxford White Maverick-so the bed still looks white.
MavChris
Macomb Michigan
23 Maverick XLT, 22 Bronco Sport, 19 Flex SEL
Hello! Looks great! I dropped the lux package also and planning to get the SIBL at a Local Line-X. I think after seeing your pictures I know I'm making a good decision. Going to wait for a month or two for the MIchigan winter to let up. I won't be hauling anything in the back until spring.
colinl
Colin
ICT
I assume many have seen it, but if not, here is a pic of the factory SIBL and you can easily see that some of the areas on the tailgate and near it are not nearly as well protected as line-x. I also believe that it's a less durable finish, kind of rubberized and not that hard to gouge or scrape out a chunk of rubbery material. If I have my truck a long time I might eventually replace the factory SIBL with Line-X, but really why I was commenting was to add another vote for skipping factory and getting Line-X, Rhino Lining, etc. This can save you a month on your build time, also. A truck comes down the line and goes offsite from the factory to get bed rails (which you can't avoid in some packages) and SIBL (which you can safely skip now that it's no longer included in Lariat).
Oh, also, this pic is a screengrab from a video of the DeeZee tailgate damper. Definitely recommend getting one of those. (y)
Ford Maverick I'm satisfied with the Line-X SIBL spray-in bedliner. PXL_20230122_201218699.TS_exported_4471_1674526205507
Hot Runr Guy
West Chicago, IL
2024 Edge SEL, 2024 Lariat AWD BAP 4K
Being that it is -2 F here this morning, I dropped mine off yesterday at my local Line-X shop, so they could bring it in the shop overnight for spraying this morning. It will be interesting to see if these temps cause any problems afterwards.
HRG
CZaugg
Curtis
Rio Rancho, NM
2023 Maverick Lariat Hybrid, 2021 Toyota Venza
Thanks for sharing. Looks great!
My converted 22 order is in production. I will have the SIBL done before I take delivery. We have a Line-X here in town that my dealership farms out too.
The same for me. However, I'm choosing to not have the dealer "farm" it out. The dealership charges $100 more than if I took the truck to LineX myself. So after I get my Maverick I'll take it in to LineX and have them do their magic. I"ll have to leave it there for the whole day and will need to go through the hassle of getting a ride back and forth to their facility. But I'll save $100.
CZaugg
Curtis
Rio Rancho, NM
It took them nearly 2 hours.
Wow. Seems pretty quick. My LineX dealer said they need a full day to complete. I saw a video from the LineX company on how they do their work. From what I saw in the video, yes a full day should be required. There is a lot of prep and detail work that takes a lot of time. Better check on that 2 hour window. Must not be "LineX" and some other company. I'd be concerned about that 2 hour window.
Murf_85
Minnesota
2001 F-150
HRG
-13 F here this morning in beautiful central MN. Windchill has it down to -23 F. I am wondering the same thing.
Murf_85
Minnesota
2001 F-150
Good point. I appreciate the reply. I will call Line-X and see. Thanks
colinl
Colin
ICT
didn't notice that before, but I agree with your concern.
they have to unbolt all the hardware like tie-downs and either remove or mask the plastic cubby covers. then they rough up the paint; not a full removal, but it's scratched up a lot to get better adhesion for the liner. (side note: I think the factory SIBL skips this step. I could be wrong.)
I wouldn't bet against someone doing that in 2 hours, but it would be surprising. I do think 4+ is typical, that's why this type of lining costs ~$500 to apply. :)
B2000
midwest
B2000
Great info in this thread. I thought about adding back on to my order but decided not to potentially screw things up. Looking forward to having this done in March or April when I get my truck.
CZaugg
Curtis
Rio Rancho, NM
I heard that too about factory spray in liner not getting the beds paint ruffed up. Some place on this forum a member who has the factory spray in liner is seeing areas where the spray in material is bubbling up and a section not adhering to the surface. Dealer is going to take care of it of course, but the point being ruffing up the surface is necessary for the material to adhere to the bed. I dropped my factory spray in liner because of it being a constrained item. After reading about what I just described above, I’m glad I dropped the factory liner. LineX cost more, but well worth it.
Lucky B
Virginia
2007 Mercedes C Class and a 2022 Maverick EB, AWD
I got the Line-X SIBL done in Fredericksburg, VA and really am pleased with it. It was arranged by the Ford dealer and I received Ford Pass points. It only took a couple hours in the morning to get it done. It was $495.
