I have decided on a lift kit. Need help with spacers.
IconicSilverMaverick
Maverick XL
I'll be going with the 1.5" spacer lift (no level) from Belltech to maintain the raked stance.
I would like to add spacers to the rear, to get those wheels to match the front. The front wheels protrude past the fender from the factory and I'd like all four corners to be uniform, for the look I'm going after.
Do you guys think the 25mm spacers from H&R on Steeda's website will allow me to accomplish this?
Thanks again to the club.
Raymundo76
Ray
Mesa Az
21 Mazda CX-5
Not trying to be snarky but lifts on a Mav seem to be like "you know what" on a boar; no ?
Maverickman74
Shane
Maui HI
Might be worth measuring your front and rear track widths before you buy anything. If you have a jack and some wood blocks you can set up all the control arms to take weight off the rubber. Or just measure at the rim. You can also take a yard stick and level or just a long level and eyeball where things sit to get an idea on where things sit.
Maverickman74
Shane
Maui HI
Nothing wrong with ground clearance. Leaving it stock is boring to me. Lowering it would also render it useless. So what is one to do?
It's just the bodywork flares out at the C-pillar into the rear bedquarters. The result is that it looks like the front wheels stick out more while the rears are even with the fender line.
Maverickman74
Shane
Maui HI
My recommendation was just to measure to make sure OP gets the best size spacer. Cheaper than staggered custom wheels or matching tire diameters with wider ones.
