Hybrid powertrain longevity
Executech
Matthew
Ford maverick
I am curious on the reliability of the hybrid. I have a 2022 I bought exactly a year ago today. I have 30,000 miles. I previously had a 2012 Prius with 130,000 miles and zero issues.
I am curious who out there has the highest mileage on one of these trucks, more specifically the hybrid.
rclee
Rob
Dayton Ohio
I have a 22 I bought in May of 22. I have 24k on it and the only issues I have had have been addressed by the dealer (TSB's, Recalls and CSP's) I also got a Maverick Yeti for doing the airbag recall. I kind of fixed my Bluetooth radio issue by getting an Apple Car Play dongle to stream my Sirius XM and MP3 music.
Overall I am very happy with my purchase!
Executech
Executech
Matthew
Ford maverick
Which dongle did you get? I have had to do the reset on the radio a lot when CarPlay fails to connect or randomly stops working.
Chicolini
Larry
East Virginia
F150s, Mustang GT Convertible, Mazda B3000
Good question! I hope you get an on point answer.
rclee
Rob
Dayton Ohio
I bought this one for 59.99 in August. It is not without it's flaws. I have to unplug it from the USB c occasionally but it works more than it doesn't.
Ford Maverick Hybrid powertrain longevity 1704042968638
Ozarkbeard
OneAlienBoi
Kev
Utah
Explorer
The 2.5 hybrid has been around for well over a decade, and is super reliable. The wiring harness was a common failure point on early hybrid builds, but it seems to be mostly resolved on later 2022,23, and 24 models.
While I wish Ecoboost drivers the best, I predicted over a year ago that we'd see the hybrid issues drop off, and Ecoboost issues start to emerge as time progressed. That's basically exactly what we're seeing.
Random
Richmond, VA
How do you do the reset? My CarPlay failed to connect today and it’s worked great for almost two years.
If you are having trouble with it dropping connection it's most likely you are connecting to it using Bluetooth (why sync 3 is drops connectivity). According to details in description it can also be connected using 5ghz WiFi so set it up to connect to phone through WiFi. Bluetooth is too slow to transfer the data packets. If that gives trouble then your cell phone tower signal may be the problem. Might get better signal if phone is near a window or maybe get a cell signal booster.
Properly maintained, I don't see why either version's PowerTrain couldn't go 200K, although the EB valves will need walnut blasting maintenance around 100K before hitting 200K. I think both are proven engines. Now the rest of the truck, well, that might be a little iffy
Bertram
Charles
Indianapolis, IN
2002 Ford Ranger, 2017 Transit Connect Wagon
I am a 32 year retiree from Ford Motor Co. Worked in their R&D department in their Indianapolis plant. Ford and Toyota codeveloped the hybrid as it is known today. The eCVT transmission is bullit proof and is nothing like a CVT that is in a Honda. An eCVT is a planetary gear system with two electric motors. A standard CVT is two variable adjustable pullys connected by a large wide belt which becomes very noisy over time and is prone to failure. My Maverick is waiting to be shipped so I will probably get it late January or February. Looking forward to many years of reliability.
2lbgill
Don
Upper Peninsula MI.
2023 XLTHybrid
A documented Escape used for a taxi in NY city went 400,000 miles before battery went kapuzzed
Executech
Executech
Matthew
Ford maverick
Been seeing a lot of hybrid issues lately and I’ve had 3+ recalls on my 2022. Recently had the strut bearings replaced and today had the exhaust heat exchanger replaced.
I have the extended warranty through granger until 125k, but these issues and all the reported problems from others do make me concerned. Currently sitting at 35k on the odometer.
I love the look and usefulness of this truck though. Recently had the front grill insert painted to match the body color. 👌
Ford Maverick Hybrid powertrain longevity IMG_0197
