I am write sure the blend date is not showing on our window stickers, for whatever reason. Mine is basically the same as @balucipher
I bet they'll be on the same truck to GrangerI am write sure the blend date is not showing on our window stickers, for whatever reason. Mine is basically the same as @balucipher
Anyone know if they ship at end of week all together or wait for enough going to the same general area?I bet they'll be on the same truck to Granger
Probably takes a day or two to sort them and load them into the right rail car upAnyone know if they ship at end of week all together or wait for enough going to the same general area?
Wrong, the Bronco is a newer chassis that the next Gen Ranger will ride on.If you check the 2021 Bronco also wasn't tested but Ranger was which is base of Bronco. https://www.nhtsa.gov/vehicle/2021/FORD/BRONCO%25204DR/SUV/4WD
https://www.nhtsa.gov/vehicle/2021/FORD/BRONCO%25202DR/SUV/4WD
https://www.nhtsa.gov/vehicle/2021/FORD/RANGER%2520SUPER%2520CREW/PU%252FCC/4WD
Well they are both built on the current T6 platform https://carbuzz.com/features/10-things-you-should-know-about-the-new-ford-broncoWrong, the Bronco is a newer chassis that the next Gen Ranger will ride on.
I'm a little bit retarded so help me out here
Does it blend?
I think it is in the "Special Order" block. Yours reads 09 06 21 and mine read 09 07 21. Just guessing, but it looks to jive with when the tracker switched to "In Production" for mine.
From what I read elsewhere this afternoon I think the MJ061 might be the blend date code. I saw something similar in another forum where users were trying to decipher what was there. Of course there are plenty of stickers out there that actually have a blend date and normal reading date, so maybe it is just the 9/6/21 date. I'd also read that date in the custom order section referred to an invoice fulfillment. Either way I think the 6th was our blend date (mine reads the same - MJ061 and 09/06/21).Both of your trucks are built. Looks like blend date was the 6th and 7th. You should probably have your rides in next 30 days
Maybe im just an idiot or don’t care but with a new truck built in 2021 I didn’t even think about crash test ratings until reading these posts. I’m sure it’s got more airbags and safety gear than anything I’ve ever driven before.First deliveries and their window sticker will be out before the crash tests are performed
Does it blend?
'Don't mean to be dense, but what is blend date? (In sure it's in this forum someplace.)I am write sure the blend date is not showing on our window stickers, for whatever reason. Mine is basically the same as @balucipher
Blend date is the day they start getting all of the parts and pieces together all in their proper place and all queued up and ready to be assembled to create your vehicle.'Don't mean to be dense, but what is blend date? (In sure it's in this forum someplace.)
