Is hybrid FWD sufficent in Ohio where I live. I deal with occasional snow and downpour. And with the weather getting worse I'm worried I'm going to need the AWD.
I always see more 4x4 vehicles in the ditch because people think they're invincible. I grew up when there was no 4WD or FWD and we got around. Yes, we occasionally got stuck, so FWD was a vast improvement. The winter tires are SO much better now, worth every penny. There used to be a VW bug ad that said something like: "Did you ever wonder how the guy who drives the snowplow gets to the snowplow?" Beetle had the engine over the drive wheels... it's the same with FWD.What cars do you see one the road in bad weather? If you see a bunch of FWD sedans (and most aren't in ditches) you should be fine. If the only thing in the road in bad weather are 4x4 trucks and AWD crossovers, you might be wise to opt for AWD.
I've driven a Toyota Prius for nearly the past decade in Indiana, right next door. It did great.Is hybrid FWD sufficent in Ohio where I live. I deal with occasional snow and downpour. And with the weather getting worse I'm worried I'm going to need the AWD.
How do people typically store their snow tires so they’re not taking up too much space or in the way. Also, is it relatively easy just to pop off and swap tires for the season?I've driven a Toyota Prius for nearly the past decade in Indiana, right next door. It did great.
I was also in the tire industry for that last decade or so. I ran winter tires alot. Sold them, tested them, and researched them extensively. If you can afford it, run winter tires. They help more in wintery conditions then AWD.
That said I didn't always have them, Prius still did great. Way better than my Dodge Neon before that. The instant torque from the electric motor is nice in snow as well.
I can't speak for others, but I'm getting a wall-mounted tire rack to hold mine.How do people typically store their snow tires so they’re not taking up too much space or in the way. Also, is it relatively easy just to pop off and swap tires for the season?
It is pretty simple and doesn't take very long to swap out wheels and tires from season to season. An air compressor comes in handy for removing, installing and maintaining pressures, but is not necessary. I did this when I had my CTS-V (man I miss that car). I have loft storage in my garage and stored the off-season tires up there when not in use- completely out of the way. I am in eastern Maryland, so we do not get tons of snow and will likely stick with the all seasons year round.I can't speak for others, but I'm getting a wall-mounted tire rack to hold mine.
We use a rolling rack like this. This particular photo is from JEGS performance parts.How do people typically store their snow tires so they’re not taking up too much space or in the way. Also, is it relatively easy just to pop off and swap tires for the season?
