Hybrid fueling tips
dwinch53
Mi
2025 XLT FWD
I've learned a few things and did a tips video for it
Excellent tip Rob, if I may add that if you fill on low instead of filling with high pumping pressure you will get a bit more gas in the tank before the click...when pumping on high you have a chance of pumping in more air right along with the gas.
Chops
Lobo
I learned how to drive in Illinois 1974 when it was illegal to pump your own gas there. Freshman year college Arizona 1975 I learned how to pump my own gas as self service pumping was legal there.
In all these years of pumping my own gas I never realized there were different flow settings on the gas pumps. Thanks for the tip!
sunglint
Wayne
Houston
2022 Hybrid
you're never supposed to "top off", that's been the advice for a couple decades. thanks for the warning though, never hurts to remind people, and a car fire would really suck
Way I remember it, once full one more click of fuel won’t hurt but after that topping off can hurt.
Seems there was talk of that last few squirts of fuel contaminating a charcoal filter. And or drawing trash into a vent somewhere, somehow. Something about screwing up tank ventilation.
This applied to all vehicles, not Hybrid specific.
Mavster Mechanic
Hybrid
If "topping off" damages a vehicle, it is a design flaw.
You may still be out of luck.
But it is still a design flaw.
FWIW my 2022 Hybrid once took 16.9 gallons to first click. Is that "automatic" topping off? And why would a customer / owner be responsible in this case?
TwoTone
MD
Outback 3.6
You're inability to follow directions isn't a design flaw.:facepalm:
Mavster Mechanic
Hybrid
Re read my example.
16.9 gallons went in. Until automatic shutoff.
Not all pumps are the same.
Not all stations are on level ground.
Chops
Lobo
EVAP systems were mandated - as were Stop/Start, airbags, backup cameras, seatbelts, non metal dashboards, etc etc etc.
Most of the mandates are helpful - some of them are stupid. Some of the mandates are “design flaws” from the start?
Mavster Mechanic
Hybrid
Start/stop was never mandated.
It was a manufacturer work around to boost MPG.
Chops
Lobo
You’re right - Start/Stop was invented not mandated. My mistake.
Although the mpg targets that WERE mandated led to the invention of start/stop.
Might be the same with EVAP? Not itself mandated but a response to an EPA mandate…
I’m old enough to remember steel dashboards and found the “soft touch” dashboards weird when introduced:)
ugh - you just made me picture like truly soft gel-like material, that you can't even wipe clean.
And use the wrong cleaner - it like melts.
Boy that would be safe!
Chops
Lobo
Our Maverick’s console & armrests are considered “soft touch”. The early non steel dashboards were called “padded”. Never any “gel filled” luckily 😬
