How-to remove factory steering wheel switches (for installing other switches such as cruise control) - DIY
Tyvemattis
Tyve
2022 Ford maverick
Throwing a quick set of pictures up on my phone for removing the factory steering wheel switches, all you need is a flathead screwdriver and a t8 torx, use the random holes in the steering wheel from behind to pry and push the little tabs with the flathead and it'll pop right off, then use the torx for the screws holding the switches on.
Ford Maverick How-to remove factory steering wheel switches (for installing other switches such as cruise control) - DIY PXL_20211231_011133929
Ford Maverick How-to remove factory steering wheel switches (for installing other switches such as cruise control) - DIY PXL_20211231_011154904
Ford Maverick How-to remove factory steering wheel switches (for installing other switches such as cruise control) - DIY PXL_20211231_011255476
Ford Maverick How-to remove factory steering wheel switches (for installing other switches such as cruise control) - DIY PXL_20211231_011547332
Ford Maverick How-to remove factory steering wheel switches (for installing other switches such as cruise control) - DIY PXL_20211231_012740376
Ford Maverick How-to remove factory steering wheel switches (for installing other switches such as cruise control) - DIY PXL_20211231_012858416
damnclose
Greenwood, IN
2016 Dodge Caravan, 2002 Chevy Silverado 4X4
Very interesting to see if you can make XLT steering wheel cruise switch work. I seen where you can order them for under $80, one place was $18 plus shipping.
bpcooper14
'08 Nissan Frontier
Nice!
bpcooper14
'08 Nissan Frontier
Happen to have a link for the $18 plus shipping? Can't seem to find it anywhere,
uh50
Howard
www.hchaney.com
2022 Maverick XL, VB, 2.0 EB
Thanks again Tyvemattis. You are making things much easier for a lot of folks that may be resistant to tinkering. Not me, I love tinkering and finding out how things work, but I appreciate your efforts because it makes me want to tinker more. Awesome job with cool stuff.:cool:
Thoron99
NC
2023 Maverick Hybrid XL
Is it difficult to get the airbag out? I’ve messed with the steering wheel on a pre airbag car, but not one with it.
Tyvemattis
Tyvemattis
Tyve
2022 Ford maverick
You have to take a smaller flat head or pick and turn the wheel 90 degrees both ways, each side there's a little tabs that you have to stick the screw driver in and press towards the steering column
houselog442
Tallahassee, FL
quick question… is there anyway you could have taken those switches out and replaced them without taking the steering wheel off?
Tyvemattis
Tyvemattis
Tyve
2022 Ford maverick
Yes they require programming, this is a prerequisite to my programming thread.
Tyvemattis
Tyvemattis
Tyve
2022 Ford maverick
It's highly unlikely. It's only 2 airbag clips, 3 wiring clips, and the steering wheel bolt. Just tear into it.
