As mentioned sweatums hair drier, fishing line.I would like to know as well. I got an actual raised metal dealer logo below my hybrid plate.
I've had luck prying those off, and then using some combination of heat, bicycle chain degreaser, goo-be-gone, or isopropyl alcohol to remove the adhesive (depending on the chemistry). If they used a foam-backed adhesive, you may be able to slide a long piece of dental floss or fishing line behind and slice off the metal/plastic logo, and then clean up the adhesive. Be careful not to leave any solvents on too long by clean well with soapy water. Don't use anything more abrasive than your fingernail to scrape at the glue.I would like to know as well. I got an actual raised metal dealer logo below my hybrid plate.
Naptha is a great paint-safe adhesive remover. A primary component in Ronson lighter fluid. +1 on the hair dryer too.Hair dryer and goo be gone will make short work of it.
