- First Name
- Monica
- Jun 21, 2021
- Huntington Beach CA
- 1992 Jeep Wrangler, 2022 Maverick XLT
- Engine
- 2.5L Hybrid
Looks Great!
Thanks for the info! I pulled up that part number you listed, it says its for a Ford Kuga.. lol is that correct? I want to get the bad boys on order asapIn an earlier post I indicated that if the upper and lower spring perches are the same as on the AWD (in my opinion) it "should" work. Or even if the upper and lower spring perches had to be purchased, it "should" work. The spring kits are not super expensive and if you do it yourself it might be worth the risk. For sure the fronts will work.
Hope this helps
Top ones are universal so no problems there. Bottom ones have a locating pin that would put the starting point of the spring winding off unless you drill a new locating hole or cut off the pin. I may still order one.Probably could have just bought the escape/bronco sport spring isolators for the left hand wound spring.
The escapes/bronco sports don't have right and left hand wound springs, just left hand wound. It theoretically would be a direct replacement with no altercations needed. The pin location should be the same to orient the springs in the proper direction. Still not sure why Ford thought this was necessary on the Maverick and not on any of the other platforms.Top ones are universal so no problems there. Bottom ones have a locating pin that would put the starting point of the spring winding off unless you drill a new locating hole or cut off the pin. I may still order one.
No, I took the stock wheels off at 38 miles and then sold them as spares except for one I put under the back. This is the closest I came to stock wheels and loweredDid you ever mock it up with the stock wheels? Im curious what that would look like, im sure not as clean as those 20's though.
Curious, maybe I missed something. But if the stock wheel is 7in. wide with an ET of 37, how did you fit an 8.5 wide wheel with a higher ET? Truck looks great btw.Thank you everyone for the positive feedback. The ride is only slightly more firm than stock. The wheels are 20x8.5 et45 with 255/50. They did not rub before and so far I don't think they are rubbing now. I did have to add a 1/2 spacer above the rear spring seat to get the stance the way I wanted it. The springs the way they came made it perfectly level. 32" ground to fender on all four. So now it's 32 on the front and 32 1/2 in the back.
