My build is simple I only ordered xlt with fx4 and 4K. Even if I was never going to to tow ( I will but will be super rare occasion) I would have got 4K just for the added coolers and better acceleration from the gearing.
Yes towing. The fx4 gear is the default 2.0 gear.Ok. So which gearing do you get if you order both.
assuming towing.
I see you have an XL . I also have an XL 4 k tow on order . If you really look ,It would cost you or me $ 4,000 dollars to move to a FX4 package . Well that's in Canada . Personally I feel a XL with 4 K tow could be more capable then a XLT with FX4 and no 4 K tow . Yes you don't have tow hooks on the front , but the hitch on the back is probable a stronger recovery point . And we can add a skid plate I am sure . The lower gearing and transmission cooler should give it the advantage .Are you sure about that? I just think it's gimmicky the way it's been marketed by Ford. I've heard it referred to by many as a skid plate package with skid plates but as far as I can tell it just replaces the plastic under engine tray with a flimsy aluminum piece. Maybe you can enlighten some of us with photos of the skid plates so there's less confusion, maybe more people would go for the FX4 package, the only thing that kind of seems worth it to me is the tow hooks but considering the fact that they found a way to mount a tow bar I think it's not long until an aftermarket solution comes for the tow hooks on the Maverick. The drive modes have already been added with Forscan, I think the black wheels are ugly and they're working on adding hill descent control with Forscan so unless the skid plate package is significantly more than just the one aluminum piece I'd personally spend the $700 on aftermarket solutions when they come out instead of the FX4 package
Same in the US - FX4 is not an option for an XL build if I recall correctly.I see you have an XL . I also have an XL 4 k tow on order . If you really look ,It would cost you or me $ 4,000 dollars to move to a FX4 package . Well that's in Canada . Personally I feel a XL with 4 K tow could be more capable then a XLT with FX4 and no 4 K tow . Yes you don't have tow hooks on the front , but the hitch on the back is probable a stronger recovery point . And we can add a skid plate I am sure . The lower gearing and transmission cooler should give it the advantage .
So typical marketing jargon BS. I would think they would offer a plate to protect the driveline and rear diff at that price.There are a couple of users who have posted oil change videos - there are at least 2 main pieces to the skid plates (a smaller forward piece, and a larger piece). I believe you are correct they are just a swap in for the standard plastic, they certainly aren't made for rock crawling!
Normally there would be at least 3 . One for the motor ,one for the transmission/transfer case and one for the gas tank . We don't have a transfer case so should be at least two .So typical marketing jargon BS. I would think they would offer a plate to protect the driveline and rear diff at that price.
I believe with the 4K towing package you also get a transmission cooler & 7 pin connector. Besides the heavy duty fan & radiator & gears. Also brake controller.I got both along with Lariat. So the FX4 wheels/tires trump the Lariat but which gearing and Rad and cooling do you get or are they more than likely identical
FX4 Heavy Duty Radiator and Engine Fan
4K Upgraded radiator, upgraded cooling fan,
p.s. Forgot, also brake controller.I got both along with Lariat. So the FX4 wheels/tires trump the Lariat but which gearing and Rad and cooling do you get or are they more than likely identical
If identical, then the buyer selecting both options is getting hosed because he is paying full price for both…the same as a buyer who only picks the 4K Tow package.my guess is that they are the same thing.
