Mine recently stopped working, there is no in line fuse for the harness, it plugs directly into the BCM connector under the dash. Has a blue wire that connects to where the cargo light pin used to go, and a red wire that I can only assume is pinned in the BCM to a constant on direct line to the battery to power the "capacitive touch" feature.
Tested the harness at both lights and am getting 12v on said blue wire when cargo light is on and grounded to black (ground wire) on the harness. Not getting any continuity on the light modules themselves but not sure if thats normal. Something tells me that Ford/Lumens wouldn't green light this kit if it wasn't fused. What happens if someone smashed a light whilst loading cargo or pinched a wire in the tailgate/lamp area. It would fry the BCM.
