Linux
Washington (Seattle Area)
2012 Mustang, 2024 Maverick Lariat
Out of curiosity, Has anyone done a 2024 hybrid (lariat) Digital escape cluster upgrade? I am assuming it should work like 2023 upgrade?
Mavvader
Adrian
Madera Ca,
2023 Maverick XL
Sorry. I don’t understand your question. You can program available drive modes with Forscan
I currently only am able to switch drive modes with the ignition key on and not full when the truck is full in drive mode. I was wondering if I just missed something on the disabling a drive mode. I read through the pages and wasn't able to see what I'm missing. I followed the instructions from page 13 of this thread.
Mavvader
Adrian
Madera Ca,
2023 Maverick XL
Take a look at disabling one of the drive modes. Earlier in the form (page 10-15ish) they solved this issue. you had to disable one of the modes since the escape cluster stores it differently. I turned it off and things got MUCH faster, dont remember which one it was exactly though
I've been reviewing them. I followed everything on page 13 of this thread. Just not sure what I missed exactly. I'm back tracking trying to identify my miss. Other than that the cluster works great.
Mavvader
Adrian
Madera Ca,
2023 Maverick XL
I was able to figure it out. I had to disable tow/haul as I missed that part earlier. It allows me to toggle through the drive modes now while on drive mode.
generalmgr
Wes
Clarion, PA
2023 Maverick XLT EB
If anyone is interested, I just listed a digital dash cluster with 8604 miles on it, in a couple Mav FB groups. $399. I installed it at about 6000 miles, but am now selling my Mav. Also selling a flat bottom heated paddle wheel $299.
Atlasmav
Isaac
Kansas
2024 2.0 eb fx4 4K tow and 2016 fusion
I just installed the escape cluster the mileage is correct but the only modes I have got working so far are the sand\snow, eco, sport, and normal are there any others I can activate? would really like to have my tow-haul and mud/ruts back if it a possibility. other than that its been awsome.
Linux
I know this has been discussed a few times but did any new info on the traction control come up. Also wanted to clarify that traction control still works? And that the only issue is not being able to toggle it on and off
Azmig88
Ted
2022 Ford Maverick 2.0 Lariat
I started that mission over two years ago. It will not work with an Escape cluster. I had one installed.
My friend installed an Explorer ST cluster and it allows traction control to switch on and off.
I have an Explorer ST cluster with about 20k miles on it. Never got around to installing it.
I ended up installing paddle shifters and had the system modified to allow for the SST (stay in any gear) to work.
I’m no longer concerned about T/C working
https://www.ebay.com/itm/3558404868...fev_1ntTp2&var=&widget_ver=artemis&media=COPY
Toddman45
Todd
St. Louis, MO
Those all digital gauges look amazing.
Derwood
Derwood
Buick and Kia
Ordered a 2020 Escape Titanium full digital gauge cluster and plugged it into my maverick, and it worked instantly. No need to do any programming to get it working, however, I'm getting a ton of fault codes from not having a lot of things that the top model Escape has vs my XL Maverick.
I will keep this as updated as I can, but at this moment the biggest issue I've ran into, is the gas gauge is only capable of showing half tank. I had quarter tank when I put the cluster in, and the new cluster was showing an 8th tank. When I filled the truck up, it was showing half tank, and I know it was full.
Update 2/2/2022: I can access call logs, the current music shows up, trip/fuel economy/seat belts work as normal
What doesn't work as of now: Full tank of gas, Calm screen, toggling of drive modes, and cruise only turns on when at a full stop. While driving I cannot turn the cruise control on, but once stopped and turned on, it works like normal.
I actually prefer manual gauges. Less expensive to fix it they crap out.
Azmig88
Ted
Most of that can easily be corrected with Forscan. Took me about 5 minutes
Azmig88
Ted
Linux
I looked through this and maybe I just missed it and I just figured to get some reiteration on the ABS module changes required for the escape cluster swap.
In forscan we disable SDM - ABS | I am assuming this doesn't actually disable ABS just disables something that allows additional drive modes?
Also i know the traction control button doesn't work after the swap, but I am assuming traction control is on by default and we can't just toggle it from the button?
Azmig88
Ted
I was on a mission to get Traction Control to turn off and on via the button on the center console, OR via the menu options in the cluster.
I took a shot at replacing the button in the center console. Hoping that might be the issue…
NOPE😕
I swapped to the Escape cluster.
I loved it, but…….
NO SUCCESS 🥲
My friend swapped the Escape cluster for an Explorer ST cluster…
TaDaaaaaaa 😀😀
It’s much nicer than the Escape Cluster and traction control CAN BE turned off and on
They’re virtually impossible to find. I have one with approximately 20K miles for sale.
Lane
Lane
Central Wisconsin
photos.app.goo.gl
2023 Area 51 Hybrid XL, 2006 VW Jetta Smyth UTE
Just to confirm - that Explorer ST cluster is for an Ecoboost, right? Won't work in a hybrid Mav?
For a hybrid... was/is a hybrid Explorer ST made?
