- First Name
- name
- Jan 13, 2022
- hinterlands
- 2022 Ford Maverick XL, AWD, 4K tow, 2.0L EcoBoost
- Engine
- 2.0L EcoBoost
This mod so far has only been tested on an XL 2.0L ecoboost with a 4 inch cluster but should work on all makes and trims.
This mod will enable a cluster option under the vehicle settings for an auto idle engine shutoff after 30 minutes.
This applies only the IPC module
the following needs to be changed
720-01-01
xCxx xxxx xxxx
leave x values as defaults
If a value of C doesn't work try values A or B instead.
That is it.
720-01-01
xCxx xxxx xxxx
That is it.
