- First Name
- name
- Jan 13, 2022
- hinterlands
- 2022 Ford Maverick XL, AWD, 4K tow, 2.0L EcoBoost
- Engine
- 2.0L EcoBoost
This mod tenatively only applies to AWD models, all trims w/o FX4 package that also already have cruise control at a minmum installed.
This mod is currently untested pending wiring done to activate the feature.
Non FX4 models are missing the wire in the harnesses to activate HDC. Once wired it can be turned on with Forscan.
This mod assumes you replace the standard instrument control switch with the stock FX4 switch that has HDC installed. You should also be able to wire in your own toggle switch directly to the IPC cluster if you don't want to change the instrument control switch.
Stock instrument control switch
Part # NZ6Z11500CA
Cost ~$73
Part # NZ6Z11500CA
Cost ~$73
