- First Name
- Caleb
- May 3, 2022
- St. Peters MO
- 2022 Maverick
- Engine
- 2.0L EcoBoost
Redline Tuning 2022+ Ford Maverick Hood QuickLIFT PLUS
Eliminate your Hood's prop rod today with Redline Tuning Hood QuickLIFT system. Progressive gas springs will lift and hold your hood without the need for a poorly placed prop-rod, simply start to lift your hood and let our QuickLIFT System take over. Your hood will lift and hold firmly at the raised position. This QuickLIFT System will fit the following Ford Maverick model years: 2022 2023.
This is a bolt in system that anyone can install. Installation manuals can be downloaded from our website for full color steps that will walk you through every step. 15 minute installation time - minimal skill level required and you will only need a socket wrench with both 10 & 13mm standard & deep-well sockets. This system uses all stock or existing locations to attach the gas struts (no drilling required).
The hood will raise to about 2" above the stock prop-rod height.
QuickLIFT PLUS - This is our all-black system... it includes black powder-coated hardware with our progressive rate gas springs with a special black e-coating and a 4 year warranty. Your hood will raise from mid-lift and remain open higher than stock prop rod height. This system is CAD designed and ships from our facility in Ann Arbor, Michigan.
QuickLIFT CARBON - A popular add-on for our QuickLIFT PLUS Systems - real carbon fiber sleeves come pre-installed on the black gas struts. Only available as an option on QuickLIFT PLUS.
Features
Features
- No compromise system design - We design and engineer our QuickLIFT systems, mounting the gas springs where they need to be for proper function. We will not compromise the system design if it affects the final function in any way, this is why Redline Tuning leads the industry.
- Simple one-handed operation, simply start to lift the hood and it will raise to the stock height unassisted in a smooth and controlled motion.
- Progressive gas springs. Our springs are not off the shelf struts, they are designed by us and manufactured to our specifications for each vehicle application. Our exclusive end-of-force dampening slows the rate of extension over the final inches of travel eliminating stress to the hood.
- QuickLIFT systems work with any hood (steel, fiberglass, SMC, carbon fiber etc.) - we design our systems using the stock hood so the main market is covered, however, our systems are designed to work with ALL aftermarket hoods unless otherwise specified. There are some applications where a unique system is required for an aftermarket hood, read the product technical specifications section for specifics on each application.
- Quick and simple installation – We design every QuickLIFT system and we write all of our own documentation. FULL COLOR installation manuals will arrive that will walk anyone through this simple installation - our customer comes first. You do NOT need to be a mechanic or car nut like us - we are so confident in our products that we post every installation manual on our website for you to review prior to ordering.
