Se ve cabrona, great workUpdate drove 45 minutes to my house they worked like factory.
No problems what so ever. Wires where all good. They will work with automatics lights too and they will turn off when you turn on high beams.
GraciasSe ve cabrona, great work
what you could do its enable the fog lamp with forscan on the ipc and if its shows up on when you press the knob then you dont need to buy the f150 switch lolI noticed today when I pushed on the headlight knob in my hybrid that it moved in and out. I wonder if the knob is the same as those labeled and connected to fog lights and is just not marked and could be used if fog lights installed and connected. has anyone else notices that the switch moves in and out?
Holy Shnike Batman!!!I noticed today when I pushed on the headlight knob in my hybrid that it moved in and out. I wonder if the knob is the same as those labeled and connected to fog lights and is just not marked and could be used if fog lights installed and connected. has anyone else notices that the switch moves in and out?
Oh, man burst my bubble!Holy Shnike Batman!!!
I HAD to go try mine.
And after 30 seconds of hopeful excitement..... I don't think there is an incognito fog lamp switch. The knob just has a tiny bit of wiggle or slop. Just like every other knob in the truck.
I Checked my other knobs and with the exception of the radio power and ac power knobs none of the other knobs had any in/out movement.what you could do its enable the fog lamp with forscan on the ipc and if its shows up on when you press the knob then you dont need to buy the f150 switch lol
I’m downAnyone that its interested on the wiring from bcm to the front bumper let me know here thanks im going to start making them. Will need to know what kind of quality you would like and what kind of fog lamps you will be using to use the conector for it.
Yuuup mark me down for one, probably will go with the F150 fogs too.Anyone that its interested on the wiring from bcm to the front bumper let me know here thanks im going to start making them. Will need to know what kind of quality you would like and what kind of fog lamps you will be using to use the conector for it.
Can the fog lights be made not to work withUpdate drove 45 minutes to my house they worked like factory.
Can the fog lights be made not to work with the automatic lights and only manually turned on with a push of the button on the dash?Update drove 45 minutes to my house they worked like factory.
