Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
Update drove 45 minutes to my house they worked like factory.
No problems what so ever. Wires where all good. They will work with automatics lights too and they will turn off when you turn on high beams.
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230123_190220
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230123_184500
MaveRican
Luis
Riverview FL
www.instagram.com
White XLT
Se ve cabrona, great work 👍🏼
mpc999
Honda
I noticed today when I pushed on the headlight knob in my hybrid that it moved in and out. I wonder if the knob is the same as those labeled and connected to fog lights and is just not marked and could be used if fog lights installed and connected. has anyone else notices that the switch moves in and out?
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
what you could do its enable the fog lamp with forscan on the ipc and if its shows up on when you press the knob then you dont need to buy the f150 switch lol
GPSMan
Many
Holy Shnike Batman!!!
I HAD to go try mine.
And after 30 seconds of hopeful excitement..... I don't think there is an incognito fog lamp switch. The knob just has a tiny bit of wiggle or slop. Just like every other knob in the truck.
mpc999
Honda
Oh, man burst my bubble!
mpc999
Honda
I Checked my other knobs and with the exception of the radio power and ac power knobs none of the other knobs had any in/out movement.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Anyone that its interested on the wiring from bcm to the front bumper let me know here thanks im going to start making them. Will need to know what kind of quality you would like and what kind of fog lamps you will be using to use the conector for it.
volksnuts
Katy,TX
Maverick Lariat HPR
I’m down
respi133
TX
Maverick Maverick
Almost cracked it lmao
Yuuup mark me down for one, probably will go with the F150 fogs too.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Dm me your Vin numbers im going to see what models you guys have. Thanks
mpc999
Honda
Can the fog lights be made not to work with
Can the fog lights be made not to work with the automatic lights and only manually turned on with a push of the button on the dash?
