Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
I wanted to Install Some Ford Fog Lamps on the Truck and seem that Ford Escape as the same Bcm conector as the Ford Maverick.
I Checked and Found that Ford Escape , Ford F150 and Ford explorer had similar headlamp switch. I Found one on Ebay that came from a Ford f150 with the factory fog lamp switch on the center dial. Install it and with forscan enable it. Heres some pics of the process. Need to enable on BCM and IPC .
UPDATE F 150 HEADLAMP SWITCH FORD PART NUMBER ML3Z11654BC .
Update hybrid fuel release door f150 part number ML3Z-11654-DB . Not tested but i belive should work.
UPDATE 2 / 3 / 2023
BCM TERMINALS PART NUMBERS WT-1003
link showing how to un pin connectors and install them.
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20221129_182732
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20221215_124444
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20221215_150128
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20221215_150229
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_105944
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_105949
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_110013
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_110028
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_110035
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_110041
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20221215_152144
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
The Ford escape comes with 2 wires that are missing from the Ford maverick Body Control Module conector. They are power for Left And Right Foglamps. So i removed the conector and added the 2 missing pins for Power to the Fog lamps. After i discover with the Help of Forscan the Bcm will actually send power to the fog lamps just need to add 2 wires and send them tru the firewall to the front bumper harness and add 2 fog lamps conectors to the front bumper harness.
After that all set and you should have a good solid oem style clean looking fog lamp setup.
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_090136
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_090142
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_091458
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_091552
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_091602
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_091607
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_094003
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_094431
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_094441
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_112020
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_145437
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_153226
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_153232
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_160411
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_163930
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_173717
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_174932
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230102_180213
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230103_103756
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230103_103801
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230103_103842
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230103_111158
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230103_111202
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230103_132751
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230103_151332
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230103_151928
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230120_175417
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230120_181823
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20230120_182228
Mabcim
Rochester, NY
22 Maverick Lariat 2.0 AWD; 20 Escape SEL 2.0 AWD
Thank You for posting this. I figured there had to be a way to use the factory switch. Great work.
snowkarver
BC, Canada
Volvo XC60, XLT Tremor
Nice work! Especially tapping the BCM and matching it up with switchgear in Forscan. That's some admirable reverse engineering.
Clarkdonbran
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 6510776C-E086-453B-AF27-44878C16EC86
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Thanks . It was just lucky guess lol once i removed the bcm conector and seen that the pins was there it was golden.
mpc999
Honda
What model year was the F150 switch from? Thanks
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
2022 Ford F150 thats how i look it up on ebay. I will see if i can find the part number for you.
ML3Z11654BC thats the Part Number
DC 51 Mav
Danny
North Chesterfield, Va
2022 Ford Maverick Lariat
Antonio, You are definitely "Da Man" I met you at the Va Maverick Meet-up back in Nov.
I put Fog Lights on My Maverick 2 times so far and yours is certainly much more professional and Factory looking. I had to cut an opening in the bumper as I have Tow Hooks. My Fog lights are fixed because of this but after using a tapered mount on the second installation they shine in the direction that I want them too now. really admire your work and you can work on my Maverick anytime !
Eagle11
Valley of the Sun
WOW., lots of work, looks great.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Thank you sir 🙏. I will be making some fog lamps bezels as soon as i learn and get the 3d printer . If you have any questions let me know.
