Dueces
Dueces
Alpha, IL
2022 AWD Maverick XL, 98 CR-V, 2004 Insight Turbo
Ok, so last night I ran a few more runs to get a good datalog, and verify the Truckette didn't do some one off craziness on my earlier drive.
The boost hit 22.47psi, and held 20-21psi to redline. The runs repeated themselves with a 12.16, 12.22, and 12.15, all at 114mph. I believe the MAP sensor is maxed, because it flatlined a couple times during my runs, and anyone who has looked ar raw data before, knows that doesn't happen! So that should show us that we have a 2.5 bar map sensor, which sucks! Unless the datalog software is only setup to read that high, but I wouldn't think that is the case.
There was ZERO knock on 2 of the 3 runs, and just .5 knock for the last half of 6th gear during the pull. I'm pretty sure that's well within the acceptable level.
Lambda was generally between .80-.82, which is consistent with all of my other datalogs. So hopefully I'm not on the edge of the fuel system. I'll need 5Star to verify that for me.
I think it's safe to say these numbers are accurate considering I ran 12.1X 4 times, and 12.2X 2 times, all at 113-114mph! QuikRik is a beast!
Burdy
Ga
01' Excursion 7.3, 82' CJ-8, 01' ACTY, 23' MAV HYB
Time to update that signature. Let us know when you eak out that 3.9 0-60 too.
Bad Actor
Christopher
SE Missouri
01 Ranger XLT, 73 Mustang Base, 02 Toyota Camry
So the 5 Star tune removes the top speed limiter?
Dueces
Dueces
Alpha, IL
Yes, any tuner can remove the limiter. Mine hasn't had the limiter since my first tune.
Romac
Roman
Louisville, KY
I apologize if I overlooked it - is there a part# for the 2.3 Corsair turbo?
93nighthawk
Eric
South Dakota
Ottocycle
Baja Georgia
23' RS6 Avant, 14' CTS-V Wagon, 87' BMW 535is
John - very impressive especially considering what you put into it. I dont have my mav yet but i have a 2.3l turbo ready and exhaust. What are you running in terms of tires and suspension?
Dueces
Dueces
Alpha, IL
So, believe it or not, that is all 100% stock!
On good surfaces, I don't even spin. The main reason for this is the factory tuning on how the torque is managed off the line. I used to hate it, because the best 60' I've done is a 1.944, but after thinking about it, having this soft roll-out style launch is probably saving the transmission and drivetrain components.
I may lower QuickRik, but not sure when. If I get some summer wheels and tires, I may actually go to a smaller diameter tire, and take advantage of using all of 6th gear, since I'm already in 6th when I cross the quarter mile.
Sorry for the long post, just ramblings of where I might take the Mav, lol.
Maverickman74
Shane
Maui HI
Any thoughts on going for a speed run one day. I know over in Wilmington OH they do the Ohio Mile run on a DHL/FedEX (or something) airstrip atleast once a year.
Dueces
Dueces
Alpha, IL
It would probably run in the upper 140s in the mile. There are rumors of a Maverick going 138.5mph in the mile, while only running 103mph in the quarter mile, so that's where I'm getting my guesstimate from. Lol
Burdy
Ga
I may lower QuickRik, but not sure when. If I get some summer wheels and tires, I may actually go to a smaller diameter wheel, and take advantage of using all of 6th gear, since I'm already in 6th when I cross the quarter mile.
I was wondering why 60's seemed high on these trucks. Make sense now. I could get 2.1s in a fwd focus on factory tires so I was thinking you guys should be able to beat 1.9xxx.
Dueces
Dueces
Alpha, IL
So I just looked at my last few runs. I'm now trapping the same 1/8th mile mph that I started running in the 1/4 mile with the stock Mav!
I also did a hp calculator based on weight and trap speed, and 114mph pushing 3700lbs, comes out to roughly 420 crank hp. Not too shabby!
Burdy
Ga
11's are imminent.
Allen King Jr
Allen
Springfield Missouri
2013 C-Max phev, 2006 Mercury Mariner, 2023 Mav XL
I bet you could put some aluminum factory diameter wheels on your Mav and get under 4s 0-60
Dueces
Dueces
Alpha, IL
Both the steelies and the aluminum rims both weigh in at 27lbs, from what I have heard. I have a plan, that can drop me down 16lbs each corner, but I don't know that I have the cash for it, lol.
