Eco vs norm mode
t arnold
n ga
2025 lariet awd hybrid
25 lariat awd hybrid, what is the real difference, driving in both seems the same to me?
Alfetta159
Vacaville, California
2023 Ford Maverick Lariat, 2014 Chevrolet Spark
I notice faster deceleration when lifting off the accelerator pedal and slower acceleration when resuming cruise control. Could be my imagination. I haven't read this anywhere in a Ford manual or done any real controlled experimentation on my part.
Hybrid - it changes the Go pedal response and coasting regen, and level the brake regen engages.
Those modes are almost all about helping you change something while driving.
Or helps with your traffic or terrain driving scenarios.
Eco more coasting regen then Normal.
Eco more brake pedal regen then Normal with pedal at same height, more range.
Eco less Go pedal response then Normal at same height, more range.
Have a problem punching out of EV mode and kicking the ICE on - perhaps Eco will help.
Have a problem punching the brakes too hard and into physical instead of more regen - perhaps Eco will help.
Cancunbadlands
Cancun
Cancun
No Eco and no Sport for me... 2024 Lariat Tremor
Name
Me
Hampton Roads, Va
2025 Lobo High
Awesome. Super helpful answer!
Eco mode dials back throttle response, shifts earlier, and even tones down the A/C to squeeze a little more efficiency out of the truck (on the hybrid it’ll lean on the electric motor more, too). It works best around town or cruising easy, but the MPG gain isn’t huge unless you’re already driving smooth. Normal mode feels way better when you need power—merging, towing, hills, etc. If you notice the A/C not blasting as hard in Eco, that’s by design to help save fuel.
PS. There's actually not a huge amount of savings in ECO mode. Most just leave it in Normal and enjoy.
Cancunbadlands
Cancun
Cancun
Is that so? 🤪
Happy to help!
TheRealEman
Eric
Maine
2024 Ford Maverick Lariat FWD
I tried 'em all but have settled into normal with my hybrid. I'm getting 46-48 local. I'm thrilled. So for me, and I'm not saying this for anyone else, I don't mess with it.
tciotti2003
Tony
Arizona
2022 Lariat
I notice when using cruise control it takes longer to get be up to set speed and since I drive mountain roads it won't ever make it back up to set speed while going uphill unless I depress the gas pedal..Much slower acceleration time as well...
Zanky
Sebastian, FL
2024 Maverick XLT Hybrid
If I didn’t have to push the ECO button everytime getting in the truck I,d use it. Wish you could select & it would stay in ECO….
On my Ecoboost
Eco makes it run like it needs a tune up.
Worthless feature IMO
commadorebob
On the EB, Eco simply slows the acceleration and shifts up faster. Basically, the opposite of sport which is punchier and sticks to lower gears longer.
On the hybrid, I'm sure it does the same and maybe goes heavier on the regen.
Personally, I prefer the more sensitive control that normal provides over Eco. I'm not a lead foot so I'm probably more efficient than Eco mode anyway...
gzebrick
Guy
Memphis, TN
25 Lariat AWD Hybrid 4K towing, '24 ioniq 6 limited AWD, '91 BRG Miata 5spd
I've a 25 hybrid AWD... Double-checked and see that the "L" position seems to ONLY increase the regen to FULL regen at all times. I sort of like that as it similar to one-pedal driving (which was great on our BOLT EUV)!
On the hybrid, Low does NOT appear to have any effect on the quasi-gearing, so it's not a traditional LOW gear... really just MAX regen. I am going to start using it along with driving in ECO mode and see what it does.
Cancunbadlands
Cancun
Cancun
