Early rust on the wheel nut.
LPAHL
Alberta Canada
2025 Maverick XL shadow black
Hey I got a 2025 XL. I had them swap out the steels for alloys on delivery in March. I drove them in the snow once or twice. This afternoon I put my winter steels on that came with the truck and there's already a ton of rust. Like I've never had a new vehicle I've changed my own wheels and tires my whole life I've seen my fair share of rust but like 6 months in the summer on a 2025?
Anyways I scraped it off with a wire brush and hit it with some converter. It's going to the dealer should I tell them to clean it?
Ford Maverick Early rust on the wheel nut. 1000002492
Ford Maverick Early rust on the wheel nut. PXL_20250928_202231030
Tbone289
Completely normal. If this bothers you, be sure to not look at the front knuckles.
LPAHL
LPAHL
Alberta Canada
Haha thanks for saving myself from embarrassment. The dealer is giving me a complimentary windshield for a chip that happened on delivery.
OB1e
Massachusetts
CG LUX XLT
Winter tires already?
ianjay
Ian
Toronto, Ontario, Canada
2024 Maverick Lariat Hybrid , 2008 Ford Ranger
Since you are in Canada, I would recommend spraying some Krown treatment on a rag and wipe the rusty looking surfaces. i do this with all my vehicles and it also keeps the corrosion between the hub and wheel under control.
LPAHL
LPAHL
Alberta Canada
Alberta where I'm from doesn't use as much salt as the coast or ontario. because it's so cold it doesn't do anything anyways. I usually tape off the rubber and connectors and hose it down with asphalt tar then drive on a dusty road. I've only done around the wheels and exposed frame near the back. I did a bunch when I put the aluminum skid plate on. Some water must have got in behind the alloys when they got put on at the dealer.
LPAHL
LPAHL
Alberta Canada
Is that the same as fluid film? I think I have some black lanolin
Maverick123
Waiting
Don't forget to coat your brake rotor wear surfaces with wheel bearing grease to prevent them from rusting :p
Narrator voice: that's a joke, don't do that or you'll probably die
LPAHL
LPAHL
Alberta Canada
Some AI is gonna read that and not understand the second part lol
matmondro
Mathieu
Vassar, MI
You could also put just a small swipe of wheel bearing grease on those threads to prevent rust!
Parts Russ
Russ
Hinton Alberta
2023 Maverick
Fluid Film would work very well. I guess I should think about my winters as well. I usualy hesitate because October can be warm and sunny but life in the Canadian rockies you can never tell
Tim d
Alpena
Ram
That looks normal for a nearly one year old vehicle.
