- First Name
- Eric
- Jul 30, 2021
- St. George, Utah
- Hot rods, Jeeps, boats
- Engine
- 2.5L Hybrid
I purchased the items to add cruise to my XL and put it in today. Lots of good posts here and on YouTube, but there were a few small things I hadn't seen posted that I'll try to cover. Not going into ForScan, plenty of good info out there on how to use it.
This is a piece of cake, ANYONE can do this with a PC (smart phone), ForScan cable, a small flat blade screwdrive and a T8 Torx bit.
Step 1: Disconnect negative battery terminal. (I forgot until after I was done and my airbag didn't go off, LMAO.)
Step 2: turn steering wheel 90 degrees (clockwise or counter, doesn't matter).
Step 3: Slide a SMALL flat blade screw driver into the hole in the back of the steering wheel as pictured. Handle down, blade pointed slightly upward.
Step 4: GENTLY press the screwdriver blade down while lightly pulling on horn/airbag with your other hand. You'll be able to feel movement when you're in the right area. The horn/airbag will pull out about a 1/2 inch.
Step 5: Rotate 180 degrees and repeat.
Here's where I think I can help others. I took a quick picture of how the horn/airbag attaches. Until you see it, it doesn't make much sense and you're just fishing. The two arrows point to the cast aluminum "hooks" that the horn/airbag secures to.
Here you can see where the screwdriver enters the steering wheel from the backside.
The little silver bar is spring loaded and has to be moved "down" to disengage from the "hooks" above.
Step 6: Simply unplug your wiring from the horn/airbag (3 simple connectors) and set it aside.
Step 7: Remove the outer ring by GENTLY prying these tangs away. Yes, they will break. Lightly pull the ring toward you while freeing up the tabs. Note: only two are silver. There are several more black ones that look similar. It may be easier to rotate the wheel to find them all. A flashlight will probably help. Remove the two wire connectors from either side of the ring.
Also, there are two small posts hidden under the trim at the bottom of the wheel. Be gentle and they'll work right out.
I neglected to take a pic of the back of the switches. Note, you can "kind of" use a Torx 10 bit but the screws are actually smaller, I'm guessing a T8. I didn't have one handy.
Grabbed the following switches off of Rock Auto, like $80 shipped, I think.
Grabbed this from Amazon.
I downloaded ForScan, paid $12 to help them and access the programming menus. Following YouTube tutorials I had everything done in about 40 minutes.
Viola, it works great.
Yes, you can do this.
[EDIT:] @Maverick2023 made an excellent video tutorial for XL Hybrid here:
Most of it applies to the EcoBoost too, except a few codes are different in ForScan between the two engine choices.
