- First Name
- name
- Jan 13, 2022
- hinterlands
- 2022 Ford Maverick XL, AWD, 4K tow, 2.0L EcoBoost
- Engine
- 2.0L EcoBoost
Good job and a few things to add.
Intelligent Adaptive Cruise Control should also available even though it isn't documented.
I can verify for sure that it is an option in the CC menu that can be turned on with forscan.
To make it work you'll first need to make sure you have traffic sign recognition working.
Then you'll need to enable the option in the IPC module and finally the BCM module setting that you changed for ACC has another forscan settable value for ACC with IACC. When I looked into this awhile back I found that the ABS values at address 760 03 02 were the same for a Maverick Lariat with ACC and an Escape with IACC so that address shouldn't need to be changed.
So what exactly is IACC well in a nutshell it adjusts the cruise control speed to whatever a posted speed limit is whenever TSR reads any speed limit sign.
https://www.ford.com/support/how-to.../what-is-intelligent-adaptive-cruise-control/
