nickn066
So Cali
Just finished rewiring the harness and the CCM module still isn't showing up on Forscan. The power and ground were switched up. Hopefully, I didn't fry the CCM?
Smh
I'm not sure if the module has reverse polarity protection... But if you are now 100% sure it's wired correctly, it might be 😔
CAS_Maverick
AJ
Los Angeles, CA
2022 Ford Maverick XLT
I figured so.
Expensive mistake on my end. Lesson learned. I was wiring the harness as it was already connected to the mounted sensor, making the orientation of the wires backwards. I should've been more careful and not do it before work 🤦.
greenweever
Peterbuilt
What size are the fuses? Trying to figure out which size fuze taps I need.
What gauge for the heat shrink wire connectors? Also, do I need this in addition to the heat shrink tubbing?
Lastly, what about the terminal distribution block or ring crimp terminal. What do you guys recommend?
fluiddynamics
22 Maverick XL
So I’m getting a camera fault, and when I go to calibrate the CCM it never moves from 0% (I drove it on the freeway for 30 minutes 2 times)
I did a module reset but that didn’t change anything… seems like something is going on with the camera causing issues…. I did do the calibration of the IPMA Lane departure which was successful, so I’m at a loss what to do next
nickn066
So Cali
Start by disconnecting the battery for at least 30 minutes, my first drive I figured it would never work, couldn't calibrate with about 2 hours of driving, faults on the dash. When I got home, I disconnected the battery for about 30 minutes to eat lunch, after connecting the battery, clearing the DTCs, tried it again. It calibrated in just a few minutes and has been flawless since.
greenweever
Peterbuilt
Anyone have recommendations for this before it gets buried in this thread?
nickn066
So Cali
They are micro2 and micro3
I used a 4:1 5/16 heat shrink
I didn't use a distribution block and just had a multi box from Amazon of ring terminals
CessPilot
Jerry
New Mexico
05 F250 SuperDut
I am hopeful that the dealer will retrofit the adaptive cruise control
CessPilot
Jerry
New Mexico
05 F250 SuperDut
I have talked to my dealer and he is hopeful that there will be a retrofit for adaptive cruise control, but it maybe a while. I hope sooner than later.
jbenjaminb
Southern California
XLT
When this installation is complete, are you able to see the ACC information on the display? Does the XLT Lux have the small gauge cluster display, or is it upgraded to the larger display found on the Lariat?
nickn066
So Cali
All size screens show the ACC and lane assist info
ltmoto
Bay area
Hi OP, thank you so much for the post.
I installed all the hardware, the CCM shows up in ForScan, and I was able to code the CCM, and calibrate the CCM, that all went well.
However, for the life of me I couldn't get the ACC to work, I think it's due to my truck being an XLT without 360 CoPilot. I did the lane keeping assist retrofit (it works perfectly), but from what I understand, that still is different from a XLT with 360.
My deviations from the tutorial:
  • IPMA 706-01-02: My XLT without 360 is: 2075 52BA 9445; an XLT with 360 package is 2075 533A A4D6; the tutorial calls for 2076 553A A4D9. I tried everything, including changing only 1 or 2 digits. Anything other than my original code would set a DTC by IPMA saying "configuration invalid", and the dash would have a warning that the pre-collision assist is not working. At the end I have to revert back to the original code; there are no DTC's, but ACC also cannot be selected. The dash has the option of "Adaptive" but if I select it, it shows "Adaptive" for a split of second and immediately jumps back to "Normal".
  • ABS 760-03-02: My XLT without 360, and an XLT with 360 are both 0200 0000 0573. The tutorial calls for 0400 0000 0575. But that code change seems to trigger a "ABS configuration invalid" DTC, and I tried a few combinations, for every case I had to revert this code to original, to get rid of the ABS DTC.
  • BdyCM 726-04-06: My XLT without 360, and an XLT with 360 are both 6025 00BC. The tutorial calls for 9025 00EC. But that seems to cause a PCM fault saying "invalid messages from BCM". I had to revert this code, to not make PCM set that DTC....
So now by reverting the 3, my vehicle only has lane keep assist, but it doesn't have the ACC / lane centering...
Anybody with a pointer? I greatly appreciate it...
(Sorry for asking a long question as a first post. I have been on this forum reading / learning for a while.)
Ford Maverick DIY HOW TO: Install adaptive cruise control in Maverick Hybrid XLT with Luxury package image_50437889.JPG
Telemachus
Jason
XL EB (sold), XLT Hybrid
Joseaoe1
Jose
Green Bay, WI
2022 Maverick XLT 2.0 4K VB, 2022 RAV4 Hybrid
Impressed. Definitely on my list of mods to consider for my 2023 hybrid XLT/lux.
already commented before with respect to heat gun. I love this step. In the Navy we had a comment that procedures should be developed with idea to keep them "sailor proof"
this one is definitely not and also might be considered more of a "let's try that," ..."grab the torch or flame thrower"
  1. Heat gun
    1. A torch can be substituted, but it is EXTREMELY easy to ignite heat shrink tubing and solder connectors with an open flame.
nickn066
So Cali
I installed all the hardwire, the CCM shows up in ForScan, and I was able to code the CCM, and calibrate the CCM, that all went well.
I helped a local owner do the install on an XL without 360 and was able to get it to work, it was all done on their computer so I don't have any of the backups. I'll see if I can get in touch with them to get a copy but I know it can be done.
