DIY FORMUFIT PVC Fat-Tire Bike Rack
CLEMav
Cleveland, Ohio
2025 Ford Maverick Tremor
I was working on an no-drilling-required aluminum bike rack design to help load our fat tire e-bikes, but I came across this company that makes furniture-grade PVC called FORMUFIT. They say it's 5x stronger, UV and impact resistant. It comes in a bunch of candy colors. You can buy it through Home Depot or directly on the manufacturer's website. They had spec sheets for the fittings, so I sketched up a design in Fusion 360 similar to other PVC bike racks, but that would allow simple velcro straps to the forward bed hook and nest inside the horizontal cavity in the front of the bed.
Ordering 3x Two pack of 1" (1-5/16" Actual OD) pipe x 60", 22 Tees, 2 elbows, 2 internal and 2 external end caps cost about $150 with free shipping. If you make no cutting mistakes, you should have one 60" piece left. Cutting was done on a metal band saw. Assembly was easy until it came to glueing. It uses the same clear PVC glue, but it doesn't give you much time to get the pipe inserted right. I chose 1" insertion instead of the full 1.25" max depth on the fittings. I pre-marked depth using painters tape and used a rubber mallet to tap them into place. There are parts you have to insert two pipes at once, which makes it more difficult to get the same depth on both. I ended up gluing the vertical parts that held the 4" wide tires and screwing the others together once it was fit in the truck. I used the grooves in the bed to align the center of each wheel. To get the tightest fitting, I started locking in the front horizontal dimensions with mallet persuasion, drilled pilot holes and adding screws. This is repeated for the other two horizontals.
I will post a diagram with final sizes if anyone is interested in building one too.
Ford Maverick DIY FORMUFIT PVC Fat-Tire Bike Rack 2022-07-31 10.19.03
Ford Maverick DIY FORMUFIT PVC Fat-Tire Bike Rack 2022-07-31 10.19.07
Ford Maverick DIY FORMUFIT PVC Fat-Tire Bike Rack 2022-07-31 10.19.11
Ford Maverick DIY FORMUFIT PVC Fat-Tire Bike Rack Colorwithbed2
Ford Maverick DIY FORMUFIT PVC Fat-Tire Bike Rack 2022-07-31 10.14.25
djaskew
Derrick Askew
Raliegh NC
Ford Maverick XLT
CLEMav, I am interested in building this for my maverick. Can you post the dimension?
clavicus
Really nicely done! Do you leave part of it unglued to be able to break it down?
FYI pvc glue with different working times can be purchased and temperature also affects working time.
Also since you cut on a band saw be sure to sand the sharpe corner off the ends of the pipes to ease insertion.
Dadmezz
Akron, Ohio
Subaru
Nice project ...and liking that VB!
CLEMav
CLEMav
Cleveland, Ohio
I glued the parts that the touch the tires, but even those could be screwed together.
CLEMav
CLEMav
Cleveland, Ohio
If you can get one that takes longer to cure, it will be easier. Sanding a bevel on all the cuts would also help.
CLEMav
CLEMav
Cleveland, Ohio
Here you go. It was designed for bikes that have 4" x 28.75" tires. The middle rack bike would have to go in back tire first. I haven't used that yet, but if I only take one bike, I may use the middle.
The dimensions are between the two fittings, the tube extends 1" into each fitting as well. The open ends that touch the walls of the beds use internal and external caps. One style goes inside the tube, I used this for the horizontal ends near the cab. The back horizontal uses outer-style end caps that provided more surface area to hold it into place.
Ford Maverick DIY FORMUFIT PVC Fat-Tire Bike Rack BikeRack3DLabled
MaverRick
Rick
2021 MachE 4EX 2022 Maverick Lariat FX4
Very nice and it has to be a lot lighter than the hitch rack I use for my Radrovers!
JimParker256
Cedar Park, TX
Very nice. Saving the link to the article and the dimensioned picture for when I get my Maverick!
