- First Name
- John
- May 3, 2023
- Waukesha, WI
- '23 Maverick Lariat EB
- Engine
- 2.0L EcoBoost
The photos below show a replacement "clean side" vent hose along with a connector for the "dirty side" hose, both of which I've purchased in preparation for a DIY double catch can installation. My understanding is that the clean side hose is difficult to remove without breaking the connectors and may well be designed for single use (not intended for reinstallation), whereas the dirty side connectors can be fairly easily removed without needing to replace them. I'm leery of attempting removal of the OEM clean side hose if there's a high likelihood the connectors will break, and I'm unsure which connector to use for the clean side catch can hose assembly.
My question is, are connectors on the dirty side compatible with the clean side? They look to be the same size fitting only with different hose diameter. Can I simply use 10AN hose and dirty side connectors (blue) for my clean side hose assembly? Will the same connectors work on either side of the vent system? Or do I have to somehow use the sacrificial (orange) connectors on the clean side with the expectation of having to replace every time I need to remove them (hopefully never)? Any insights/guidance would be appreciated.
