Just to be clear, there are about four plastic fasteners in the wheel well area directly behind the light. Once you remove these, it will allow enough opening behind the light to get your hand back there. To remove the light, you can press from the front and retract the part of the light assembly that holds the light in place. Don't try to pry the light out. (Revised... Note this instruction is for passenger side only. There are obstructions on the driver's side. Also, Redneck garage has instructions video for removing the light without removing the four fasteners.)The foolproof way to remove the cover is to partially remove the shield underneath so you can get you hand behind and push the tab on the light. after than you can put everything back since the cover will snap back in.
