Camper Shell: Seal around back cab window?
greenweever
Peterbuilt
Anyone confirmed a seal to go between the camper shell and the back cab window that works well? Also, did you have to add any type of seal between the camper shell and the top of the truck bed and around the tailgate? If so, any links to those products as well would be appreciated.
Mephisto613
Phoenix AZ
2022 Maverick XL Hybrid
I just had an ARE v-series cap installed. There is a gap. You need the gap between the topper and the cab for flex. A lot of the toppers come with fold down windows so you can clean out the space between the rear window and the topper. I wouldn't put anything in to seal mine. It's water tight enough. Obviously not the same as an SUV that is a solid body panel , but these aren't SUVs. It's a mod to a small pickup truck
Ford Maverick Camper Shell: Seal around back cab window? 20230126_122336
Ford Maverick Camper Shell: Seal around back cab window? 20230126_122325
BlueRaven
Iowa
24 Mav, 01 CRV
its unibody. if the bed is flexing. you have damage. i will be using a one sided stick camper seal between the cab and shell. it will not hurt anything and keep rain and snow out of the gap.
