Blog Share: How Do Dash Cams Work❓
WOLFBOX
Diamond Sponsor
Florent
2024 Maverick XLT
For those of you who know little about dash cams, this blog offers some basic information👇 Hope it helps.
How Do Dash Cams Work?
  • What Are Dash Cams Used For?
  • How Does A Dash Cam Work?
  • How Much Is A Dash Cam?
  • How Does Dash Cams Record Videos?
  • Where Is Dash Cam Footage Stored?
  • How Long Does a Dash Cam Record For?
  • Does Dash Cam Work When Car is Off?
  • How Do I Select the Right Dash Cam?
  • Are Dash Cams Legal?
Leave your thoughts after reading it. If you find it helpful, don't hesitate to hit the "like"
Dave O
New Smyrna Beach Florida
I don’t need a smart mirror or rear camera option for my 2025 Maverick Lariat AWD Hybrid but I would like to install a dash cam that I can have a clean install without running wires across my dash and have a power cord using one of my charging ports.
Do you have a solution I can pull power from above the existing OEM mirror without routing cables along the window shield, pillars and door trim to the under dash fuse box?
WOLFBOX
WOLFBOX
Diamond Sponsor
Florent
2024 Maverick XLT
Sorry, we don't have that solution yet. If you hardwire it, you don't need to use the charging ports. Connect it to the fuse box, tuck the cables, everything looks clean.
Dave O
Okay thank you for the recommendation
