Does the storage cubby in the bed have a drain?
How likely is it to get water in there?
Unlikely at all. Not sure where the water would come from or how this is possible. Even if you spill water on the back bench, you will need a shit load of water to soak through those bench cushion, before it hits that area.How likely is it to get water in there?
I think they mean the cubby in the back bedUnlikely at all. Not sure where the water would come from or how this is possible. Even if you spill water on the back bench, you will need a shit load of water to soak through those bench cushion, before it hits that area.
That is correct. I mean the one in the bed.I think they mean the cubby in the back bed
I reread the OP post, and I believe you are correct.I think they mean the cubby in the back bed
I was thinking about using it to cool some brewskis, but I wouldn't want to do that unless there's a drain. So, I thought I'd ask.I reread the OP post, and I believe you are correct.
@mamboman777
I misunderstood your thread topic. If you have a good tonneau cover on your Maverick bed, I do not believe those two cubby storage spaces will get wet.
Easily fixed with a drain hole installation tool.I was thinking about using it to cool some brewskis, but I wouldn't want to do that unless there's a drain. So, I thought I'd ask.
Use a plastic bag (or 2) for a liner, add ice, add beverages, drink, remove plastic liner, then dumped the melted ice.I was thinking about using it to cool some brewskis, but I wouldn't want to do that unless there's a drain. So, I thought I'd ask.
I mean, there is a bottle opener on the bed….I don’t know if you had heard about that yet. Oh, and they also cut off the door handles so 1L bottles can fit upright in the door.I was thinking about using it to cool some brewskis, but I wouldn't want to do that unless there's a drain. So, I thought I'd ask.
That's to say that there isn't one in there already?
Oh, sorry, I don't know if it does or not. But if not it is easily fixed with the above tool.That's to say that there isn't one in there already?
FLEX BED! diy!Does the storage cubby in the bed have a drain?
