Auto dimming headlights not working
marsman02144
Somerville MA
2023 Ford Maverick
I have a 2023 XLT WITH 2500 miles on it with a luxury package. Suddenly my auto dim head lights are no longer working. I can find a way to turn them back on in setting. How do I get them to start working again?
710-oil-614
Cal
2025 Hybrid AWD Lariat
Auto-dimming headlights?
The headlights can default to auto on/off but they do not dim.
You can also have auto hi-beams that can be activated by pulling on the left turn signal stalk
Ozarkbeard
Yes, they do. That feature (or annoyance) is on all trim levels. I turned it off in the vehicle settings of my XL, because it just doesn't work well at all on the hilly curvy roads where I live.
OP: Toggling the setting OFF & back ON again, in your Vehicle settings may fix it.
710-oil-614
Cal
You mean your headlights DIM more than lo-beam? I've never heard of such a thing.
Don't forget the second part of my original comment that addressed auto hi-beams:
Ford Maverick Auto dimming headlights not working 1704990497988
Ford Motor Company
Official Ford Account
Dearborn, mi
Hello! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this headlight concern? Thank you!
Do you have the auto button on dash turned on to select(yellow is on)? If so then when it gets dark enough the trucks lights will shine.
Phil Ricotta
Phil
Ontario Canada
2023 Atlas Blue XLT LUX HYBRID - CP360
I have found that if you push the High Beam Lever forward they go to High Beams Always On Mode if you push it again it goes into Auto High Beam Mode. Repeatedly pushing it alternates between Always on to Auto Lowering Mode. Look for the Blue indicator on you display to show what Mode you are in.
Carjack
Belleville, IL
2014 Taurus
So far I really like the feature.
bh0307
billy
tyler, tx.
2018 f150
Phil you are right thats how it works
Oscarcat
Eric
Encinitas California
There is some confusion here. There are two "automatic" headlight features. 1. Set the round light selection knob to the left of the steering wheel to the icon with the "A" circled = headlights turn on in low light conditions but NOT high beams. 2. Auto high beam - turn that off or on in "settings". If you set it to "off" you will manually turn on high beams with the stalk. If you set auto high beam to "on" a sensor will turn on high beams when ambient light is low and there are no oncoming vehicles with headlights detected by the sensor. Does that help?
marsman02144
Somerville MA
2023 Ford Maverick
Thanks for the info. However when I go to settings I don't have an option for setting "Auto High Beams". The feature worked when I first got the truck and I like it as I travel the back roads at night and they dimming and then go back to high beams after a car had passed. Any other thoughts?
710-oil-614
Cal
Zero confusion on my end. I understand exactly how the headlights work.
subiefiles
Westside
MY23 Mav Lariat (+lots of Subarus)
I dont have any setting on my '23 Lariat to disable the auto high beams. They are very annoying...
