Apple CarPlay not working
ClemsonU88
NC
To use Apple CarPlay the manual says to: 1) Connect your device to a USB port, 2) Follow the instructions on the touch screen.
I connect my iPhone 11 using a usb cable, but instead of getting instructions, I get the following 2 messages toggling: "The inserted USB device is not responding" and "Indexing G's iPhone".
Additional information. My phone used to connect to Apple CarPlay when I plugged it in, but recently I went to Italy, switched my SIM card, got an Italian phone plan, came back to the US, put my old SIM back in, and have been using the phone as I did before I went to Italy with my old phone plan. However, since I got back, when I plug my phone in, I get those 2 messages and no instructions. Also, the phone has the most recent update.
Anyone else experience this? Anyone know the solution? Thanks.
LM42
Luke
Phoenix, AZ
Maverick XLT FX4 EB
Are you using an actual Apple Lightening cord, and is your phone updated to the latest software version? I find that specific to CarPlay the iPhone is very particular about cords.
ClemsonU88
ClemsonU88
NC
Just before your comment, I edited my post to say my phone has the most recent update, but thanks for mentioning that. I think I'm using an actual Apple cord, but I'll double check.
jwilson
NJ
PENDING MAV XLT/Hybrid
ClemsonU88
ClemsonU88
NC
Nothing to brag about
I would try a different USB cable. I bought one that has a higher transfer rate and haven't had any issues.
ClemsonU88
ClemsonU88
NC
Problem solved. When in Italy, we needed CarPlay off so we could plug into the USB port (for charging) but not have the phone try to do CarPlay (because it wouldn't work with the Citreon car's radio), so my son (he's the smart one) figured out how to turn off CarPlay. I remembered him doing that but didn't know all the steps he did. I thought I could just go into Settings/General & turn it on/off. It's more involved than that.
To turn on/off Apple CarPlay, click the following links on your phone:
Settings
Screen Time
Content & Privacy Restrictions
Allowed Apps
CarPlay
(turn on/off as you desire)
I thought the CarPlay setting was supposed to be in Settings under General, but when I clicked on General, it wasn't there. It wasn't there, because my son had restricted it using the steps above. Once you unrestrict, it shows up under General again.
ClemsonU88
ClemsonU88
NC
Thanks, but it was a user error...I had restricted CarPlay.
Beekeo
Massachusetts
2022 Ford Maverick, 2018 Ford Escape
glad to see Clemson found his solution!
We recently had an issue driving from SC to MA (14 to 16 hours, depending on traffic and stops), where the carplay connection worked fine for 8-10 hours then started cutting out with no amount of power-cycling of the car, phone, swapping phones, swapping to a second cable, twiddling settings would resolve, made navigating around bad traffic and thunderstorms even more frustrating.
eventually just resorted to my wife holding her phone and calling out the turns.
an hour or two later, we plugged my phone back in and it worked just fine (and has continued to be fine for running errands etc).
my untested suspicion is that both of the cables were in use for charging and data, and the MFi chips in the plugs were overheating (one cable was Apple usb-c, one was an Amazon Essentials usb-standard). I need to bring some spare cables the next time we are driving extra long distances (but hopefully not soon)
ClemsonU88
ClemsonU88
NC
Interesting. My previous truck's radio (Nissan Frontier) worked perfectly until I would play it for an hour or two. Then it started getting flaky. Sometimes it would shut down for no reason, freeze, or glitch in other ways.
It seems like things get tested for the short-medium time frames. Anything longer than an hour...you're on your own. :)
Good luck with you hypothesis & testing. I hope not to be driving that long any time soon.
bbyBlue
Chicago
2022 Ford Maverick (VB), 1986 Lincoln Mark 7
Also one tip for I phone users. Spend the money on a OEM apple usb-C to lighting. Charges my phone super fast and is super reliable. I had issues with the ford radio and after market cables on my ranger. Once the mav was built I got a oem apple usb-c and all the issues I had with the rangers sync went away.
The entire touchscreen system is problematic. 1 text = 3 notifications on Ford touchscreen displaying a random contacts name sometimes. Android Auto with usb c plugged in will not connect to my music or maps, seems to be glitching. Bluetooth looses connection for no reason when making calls "sometimes".
Bluetooth audio I have to connect manually almost every time I don't drive the car for awhile. I click sources and it always defaults to F***ing AM radio.
I'll check for an update, but after a year of ownership these issues annoy me.
lajlmt
Lance
Rio Rancho
‘23 Maverick XLT LUX
Roman curse!
