American Flag that will fit the rear sliding glass?
Nomav
Stephen
NC
2021 FJG Mach 1 HP
Has anyone found an American Flag that will fit the rear sliding glass? I searched but did not see anything posted. Thanks!
Watchcmdr
Az
Alto blue Lariat, fx4, 4k
Nomav
Nomav
Stephen
NC
2021 FJG Mach 1 HP
Watchcmdr
Az
I saw these initially but wanted one that would blend in more with the tinted windows. Thanks!
Sorry for the crappy picture, but it. Blends in pretty good
Ford Maverick American Flag that will fit the rear sliding glass? 4C162F17-9801-47D1-B23D-DDC8B716A14C
Nomav
Nomav
Stephen
NC
2021 FJG Mach 1 HP
Thanks for sharing! Did you say you have this one? Yea, I am surprised there is not one made in the USA.
When you installed it how long does it take to adhere to the window? Thanks!
Watchcmdr
Az
Right away. Make sure it’s square with the window before sticking it on, you only get one try.
Nomav
Nomav
Stephen
NC
2021 FJG Mach 1 HP
Well, since the instructions were somewhat vague other than saying use soapy water I ended using a mixture of detail spray which is like a waterless soap mixture and the squeegee. Once it started drying I was able to get one side to stick and worked the backing paper off gently. This reminded when I was working with PPF on my headlights. I kept slightly wetting it down until I got the position correct which allowed me to be able to pull it off to correct. We shall see if it stays on!
Thanks replying back!
Ford Maverick American Flag that will fit the rear sliding glass? 20230421_165906
