- First Name
- Rob
- Jul 15, 2021
- Dayton Ohio
- 2022 XLT Maverick Lux,A51,Hybrid,Rear Slider.
- Engine
- 2.5L Hybrid
Hi Steve, I connect to my home wifi (in the garage) and it says "connected to yourwifinamehere" Then I go to check for updates and it spins for a bit and times out. I tried about 15 times and said the hell with it.Please explain more.
Do you see that the Maverick's WiFi is actually connected to your home wifi or hotspot. My home wifi signal is very weak so connecting to that is problematic for me thus I use my Android Phone HotSpot which had no issues connecting.
With a connection I then select "check for updates". Usually it takes me two or three times for the update to show.
Then I select "download the update". The update is around 446 MB in size so it takes about 5-10 minutes to download.
Then the instal. Be patient here as it looks like it is hanging at 100% but waiting about 5 minutes it says the install in done.
If you check the current version it will still show the old one. In about a day and a few cycles of powering on and off the Maverick a message on the infotainment screen will show "installation completed"
The latest update G2.1.0.1_R22362A (446MB) is documented here:
(XL & XLT) Update for Infotainment System 01/07/23
I saw some instructions on MTC about doing a reset on the radio (power and fast forward button) and tried again. I did the same sequence and connected to my iPhone12 with the same result. I even told it to forget my connection and tried both ways again.
It never downloads anything. I am stumped. I would be thrilled if it tried to download and crash. That way I knew it was talking to Ford at some point.
