- First Name
- Kent
- Jul 10, 2022
- Mason City, IA
- 2022 Ford Maverick
- Engine
- 2.0L EcoBoost
I recently responded to someone who asked about a cheaper, easier way to add a tow hitch. I can't find that thread, but the gist of it was: Could we bolt an affordable receiver onto the bottom of the bumper bar, or crash bar if you prefer.
https://www.harborfreight.com/5000-...e=go&utm_medium=social&utm_campaign=shortener
I had several questions about that option, so I got under it today to get some answers:
Is the crash bar accessible enough to run bolts through it? Yes! It would be quite easy to drill up through it and bolt it on.
Does the geometry of the crash bar allow for the receiver to be positioned behind that blank/cut-out piece in the plastic bumper skin? Yes! it would line up perfectly to look like a factory option! Also removing that blank looks straight forward and should look clean.
Is the crash bar constructed with the same specs as the factory tow hitch? I don't know. But after looking at it closely, my guess is that the factory tow hitch is the exact same piece, with a receiver welded onto it.
I took some measurements of the crash bar too. It measures 2"X3.25". I invite anyone who has a factory tow hitch to take some measurements and pics of the holes in your hitch, to show the thickness/gauge of the steel. If anyone else has knowledge of this, your advice will be appreciated.
