Yes, because of the transmission oil cooler. Yes the radiator and the fan are increased with just the FX4 package but the life blood of a transmission is the oil. Once the trany oil gets too hot you will lose a lot of its lubrication properties. Now, if you don’t need to tow more than 2k lbs then no, you don’t need the 4K towing package. I myself am getting FX4 and the 4K towing. I want to tow an off road style tear drop travel trailer.If ordering FX4 do I need 4 K as well?
I am going to disagree with you on this since an aftermarket transmission cooler is viable and economically cheaper second option to prolong the life of a transmission when not needing the extra tow capacity.Yes, because of the transmission oil cooler. Yes the radiator and the fan are increased with just the FX4 package but the life blood of a transmission is the oil. Once the trany oil gets too hot you will lose a lot of its lubrication properties. Now, if you don’t need to tow more than 2k lbs then no, you don’t need the 4K towing package. I myself am getting FX4 and the 4K towing. I want to tow an off road style tear drop travel trailer.
And the 4k is only 745$. Pretty good deal for a tranny cooler and bigger radiator even if you don’t tow anything I think.Just having the transmission oil cooler adds years of life to the transmission even if you don't tow.
The rear axle is also geared differently. 4k packages have a 3.81 gear ratio. Non 4k packages depending the engine either have a 3.63 gear ratio for ecoboost engines or a 2.91 gear ratio for hybrids.And the 4k is only 745$. Pretty good deal for a tranny cooler and bigger radiator even if you don’t tow anything I think.
3.81. That’s going to be quick! Hope it doesn’t rev too high at hiway speed. Anyone know what rpm that runs at say 70 mph?The rear axle is also geared differently. 4k packages have a 3.81 gear ratio. Non 4k packages depending the engine either have a 3.63 gear ratio for ecoboost engines or a 2.91 gear ratio for hybrids.
