FutureOwnerInTN
Nashville
SUV/Car
https://www.roadandtrack.com/news/a36697224/ford-maverick-had-to-be-a-hybrid/
The Ford Maverick Had to Be a Hybrid
How Ford is restoring hopes of a mini truck renaissance with a little electric help.
JUN 11, 2021
Ford, using a mix of imposed media embargoes, carefully metered press access and psychological manipulation, orchestrated an orgiastic blowout of coverage for the debut of its new Maverick compact truck. But missing from the Vesuvian spew of videos, blog posts and pandering news items was some important perspective. That includes acknowledgement that the Maverick will be the first small truck to be sold in the United States as a gas-electric hybrid. And the regulatory reason that the Maverick had to be available as a hybrid.
It comes down to how the government calculates fuel economy targets for light trucks. It’s a convoluted and somewhat contradictory voodoo formula that applies different efficiency standards to vehicles based upon their “footprint.” That is basically, the area a vehicle occupies – its length multiplied by its track width. The bigger shadow a truck casts, the easier the fuel economy standards it must meet. It’s a method of regulation that’s practically killed the regular cab pickup truck and made introducing smaller trucks, until the Maverick, a virtual impossibility.
Think of it this way. Say you’re Toyota and you have the Tacoma to sell. Back in 2014, the regular cab Taco ran 190.4-inches long while the extended Access Cab model was 208.1-inches. The longest version that year was the Double Cab longbed at 221.3-inches. But while they differed in length, they were all basically the same truck. They were available with the same four- and six-cylinder engines; used the same transmission and powertrain components and shared virtually all their chassis pieces. Most importantly, all the 4x2 models had a 61.0-inch wide track while the 4x4s and PreRunner (4x2s that look like 4x4s) had 63.0-inch front and 63.4-inch rear tracks. Now let’s do some math.
Multiply the regular cab 2014 Tacoma 4x2’s 190.4-inch wheelbase by its 61.0-inch track and what results is a footprint of 11,614.4 square inches (80.66 square feet). Meanwhile a similar Access Cab model went out at 12,694.1 square inches (88.15 square feet) and the Double Cab crushed that at 13,300.13 square inches (92.36 square feet). That’s more than nine percent larger for the Access Cab and almost 15 percent larger for the Double Cab. Those numbers grow even more stark for wider 4x4 models.
Now it gets weird. Here’s the formula for determining the target fuel economy (T) of light trucks to meet Corporate Average Fuel Economy (CAFÉ) goals. These standards went into effect for 2011.
T = [1/a + (1/b – 1/a) e(x-c)/d/(1 + e(x-c)/d)]-1
where:
T – fuel economy target, mpg
a – maximum fuel economy target, mpg
b – minimum fuel economy target, mpg
c – footprint value at which the fuel economy target is midway between a and b, in square feet
d – parameter defining the rate at which the value of targets decline from the largest to smallest values, in square feet
e = 2.718
x – footprint of the vehicle model, in square feet
Footprint, that “x” value, matters a lot in this equation. And it matters even more in the context of managing a portfolio of diverse products across a manufacturer’s range. What it meant for Toyota back in 2014 was that there’d be no regular cab Tacoma for 2015. And there hasn’t been a regular cab Tacoma since. The Tundra regular cab was offed after the 2014 model year as well.
For manufacturers, killing the regular cab trucks was no great loss of business. Consumers have a strong preference for extended and crew cab trucks and the companies were unlikely to lose marginal sales. Larger medium- and heavy-duty trucks for commercial customers are still available with regular cabs.
But for the same reason that regular cabs had to die, so did the possibility of truly small trucks. Over the years, I’ve asked virtually all the truck builders about opportunities for a small truck in America. They all recognized there was a market, but that with the current footprint regulations there was no way to profitably get one to market. But with the hybrid version as the base configuration, Ford seems to have overcome that hurdle.
Hybrid systems have become more robust in operation and much cheaper to build. Ford and Toyota have been out front on hybrids for a while, so it's a good bet that Toyota could be next to offer a mini truck of its own. Toyota’s strength in the truck market has long been the Tacoma, so there’s no reason not to counterattack against the Maverick. After that, the other truck builders will follow in the hope of attracting entry-level buyers who become lifelong customers. And hybridization is the secret sauce that makes it possible.
Overhype and ridiculous hyperbole aside, the Maverick will herald the return of mini-truckin’. Dude. And dudettes.
oljackfrost
Minnesota
This should be an answer for all those on the forum asking for a regular or super cab Maverick.
FirstOnRaceDay
Devin
Toledo Ohio
2000 Mercury Grand Marquis LS
EPA system is so broken.
First this. THEN you have things like the 2.0 diesel Eco blue engine not being approved by the EPA because it pollutes too much, but yet the 3.0 power stroke is approved because it doesn’t pollute too much how does that make any sense. Because it is based on displacement not what the engine is going into.
But also I think it is smart for Ford’s marketing. This will bring more people into the Hybrid and EV world. Allowing for a slow transition to a full EV line up
TooManyVehicles
Upstate NY
15 F150 XLT, 21 BS Badlands, 22 Mav Hybrid
Agreed, this article lays out just how screwed up the EPA and these laws are.
OTOH, Ford has taken lemons and made lemonade with introducing the Maverick with Hybrid standard. It also can influence the price points. For example, perhaps Ford's cost for the Hybrid system (engine + electric motors + battery pack + hybrid components) might be HIGHER than the cost for the Eco-Boost engine. But needing to drive fleet average MPG higher, they influence buying decisions by having the Eco-Boost as the higher cost option and also by requiring it for a desirable option (AWD).
Those who don't need AWD or the more powerful engines benefit from this pricing distortion.
Wanted33
Down South in Dixie
Mustang GT, Jeep Wrangler
Well, it is the government after all. My dear old Dad used to say, "They could screw up an anvil with a claw hammer". :)
CACTI_HYBRID
Rick
Meridian, ID
2022 Ford Maverick XL Hybrid
I'm very happy the base Maverick is a hybrid. Up until this, you had to pay more for a hybrid option if a car model even had it. The Maverick might be the only truck and certainly is the only compact truck to offer a hybrid. They also took it to the Hyundai Santa Cruz, their prime competition. The Cruz announced ho hum mileage figures too so score goes to the Mav here. Well played Ford!
Leuf
Kevin
NH
2024 Maverick XL AWD
No. I want the shorter cab because I want a longer bed, not a shorter truck. I wouldn't care if the truck was 6" longer.
Speed2000
Woodstock Ga
Acura TSX Sportwagon
The Ranger supercab and super crew are both 211 inches long, Adding a foot of bed length and subtracting a foot of cabin space leaves the same footprint. Ford is calling this a pick up so the emphasis should be on how much stuff will fit in the pick up bed, not how many humans you can cram into the cab.
If Ford had offered a supercab version with a foot longer bed along with the crew cab, they would already have my reservation because I think its perfect otherwise.
CACTI_HYBRID
Rick
Meridian, ID
Just curious...What is it you haul that a foot difference in bed length makes a difference and how often do you haul loads like that? People sometimes seem to get hung up on features they will only use 10% of the time.
Speed2000
Woodstock Ga
My dirtbike. Its about 78 inches long so I'd need a six foot bed with tailgate down to fit. Empty nester with no need for back seats. Some would say just get a trailer, but if I wanted to do that, I'd just put a hitch on my wagon and save $25,000.
oljackfrost
Minnesota
In that case you want a Ranger, it’s longer.
oljackfrost
Minnesota
Sounds like you really want a new Ranger, it’s just what you are asking for.
Speed2000
Woodstock Ga
I have been looking at Rangers, ...downside is I think its a bit too tall for my garage, the bed and sides are higher, couple that with rear wheel drive so I'd need 4x4 (add $4000 which you don't really need with front wheel drive) and nearly half the MPG.
Maybe someone will come out with a rail type of ramp that extends the tailgate a bit so it would fit.
rtsherry73
Richard
Boynton Beach, Florida
Toyota
Wow. What a great first sentence.
Hemingway would "orgiastically" roll over in his casket in appreciation of that first sentence.
"He was an old man who fished alone from a skiff in the gulf stream, and he was 84 days now without taking a fish."
