Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
Ok here we go with the wiring . Corsair clock spring connector . I think i made a mistake will not know if it works or not with the steering wheel i bought but i think with the lincon Corsair steering wheel should be almost plug and play. this information its personal opinion not fact i actually not yet have tried this yet but i i will try it when parts arrived.
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697394374680
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697394515447
should be Pin 5 and pin 6 behind steering wheel on clock spring. Pin 1 and pin 2 on the steering wheel harness.
im adding a picture of the Corsair steering wheel but the one i bought its from another vehicle. just for reference.
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697394699473
Transmission paddle shifters wires diagram. adding here.
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697394782196
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697394822877
Now i will be adding the Ford Maverick 2022 XL since thats the one i drive . Mine already has Cruse Control added and other switches.
PCM Connector from 2022 Ford Maverick shows pin 5 and pin 6 from pcm having shifter up and down . Good sign """
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697395331049
Connector from clock spring to steering wheel shows pins could be added for the steering wheel .
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697395618673
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697395554460
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697395940411
For Information Lincon Corsair comes with the same Transmission as the Ford Maverick 8f35 im not really sure this will work on hybrids .
Im adding this because this its the steering wheel i bought. from UK ford Fiesta
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697396675130
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697396769423
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697396820283
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 1697396966220
looks like im going to have to changed the harness on the steering wheel cause it might be differently. But for now im going to have to check this harness and If Forscan allows me to change gear lever selection with sport. I feel i did not needed the clock spring from the corsair. As im not adding heated steering wheel. but if i wanted to i could buy clock spring from ford escape with heated steering wheel and should work. this for now its a theory i could be wrong will only know when the steering wheel gets here and im able to work on it on the shop but for me looks possible. wish me luck lol
Adrienhyatt
Camde
Macao
Sadiewhite
I'm really intrigued by your concept involving the OEM Ford driving lights. I'm contemplating a similar approach, but with LED driving lights and a pair of amber fog lights. From breaking news to entertainment updates, JeetBuzz https://jtbzz.com/app/ has it all covered. To give you an idea, I've created a mockup using aluminum plates cut to match the lens shapes. I've also pondered the possibility of using round lights as an alternative option.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
The wheel came in while i was in vaction i think its time to mess with it during the week if i get w chance since i got a lot of work that will need to be done at work.
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231024_162127
MM Mav
Amy
Great Lakes Region
Sucks when work at work takes away from the personal work you want to do at work 😋🤭
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Fact but got to work to make money wish i had a youtube channel or sponsors i got so much ideas but not time or money lol 😅
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Welp i tried installing and messing with it after the real work lol. Everything fit right . Now im messing with trying to figure out programing and switches with forscan . Pictures you can tell the differences between the factory 2022 XL clockspring and steering Control Module. Im thinking i might have some issues with the steering control module i bought from ebay. Hopefully just a programing issue . Im going to try to enable heated steering wheel , drive modes on steering wheel and paddle shifters.
The problem im having right now i cant seem to find a way to access with Forscan The Gear Selector Module. To be able to enable paddle shifter. Will update as soon as i get this going lol. Heres some pictures of the process.
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_164428
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_164511
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_164917
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_165136
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_165146
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_170130
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_170137
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_171815
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_171818
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_171823
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_171831
Ford Maverick 22 XL VB Paddle shifters ,f150 Fog light Switch and Fog lights, Rotiforms Wheels Scale Suspension lowered and much more Oem Ford Accesories. 20231025_173132
Mabcim
Rochester, NY
22 Maverick Lariat 2.0 AWD; 20 Escape SEL 2.0 AWD
With the way many things Ford has that are pretty much the same, it has surprised me the variations in wheel/clock spring/connector. Sure, there might be some wires missing from the connector to an under dash module, but you would think it would be as simple as that (adding wirings, maybe swap pins at the connector). Not sure why Ford has so many variations.
As far as Forscan, you can try going on the Forscan forum and reaching out to the developers. I’ve heard they are fairly responsive and easy to work with.
If anyone can figure this out, I’m sure you can. Keep at it!
ryan2366
Ryan
Maverick Lariat - Hybrid
Anyway ideas on how to make the paddle shifters from a Ford Kuga steering wheel control the low button on the rotary dial 😉
jewc75
I want to commend you on posting the fog light info and everything else you've posted. The fog light stuff will come in handy for me once i can walk again.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Let me know if you have any questions . The fog lights where easy with the f150 switch and the wiring i made for them.
jewc75
Crazy.
What did the fx4 valance cost you at employee pricing?
TopGun22
TopGun
Ontario
SONATA GL Sport
I ordered the front harness for a BS that includes the fog lights with the hope the foglight connectors can be turned hot with some programming
How did you make out with this ?
