I agree with RichT47, Same age and problems. When I got my 25 Lariat AWD it seems my dealer had more important things than how to explain things to an "old fart" . Mostly it was trial and error I know about 20% of what options the computer, car, thinks I should know. One of the things that pissed me off was the elimination of the CD drive, while I travel I always listened to "books on tape". After trial and many errors I figured out that I can copy the CDs onto mt Mac computer, one at a time, to an empty folder than change the names of the files to something simple like if the "BOT" has 12 disks I list the file as 01 (disk # 1 than each file on that disk with an alphabet A. It should look like this disk 1 file (1 0A) through disk 12 file 13 (12M). once you have all the disk files renamed. Save it to the music program on the Mac. highlight all the files you entered, Go to the "file" tab in the top line drop down to the "convert" sub menu and select "Create an AAC Version". after that you will have two of each file names. Highlight only the files that do not ens in AAC and delete only those files. you will now have your "BOT" files ready to copy on a flash drive and play on a USB A or the USB C. One last thing is to make sure that your flash drive is formatted as a "FAT32" , Ex Fat or MS-DOS (FAT)
Show full message↓
