Solar Mavs
Dedicated the 2021 Texas power crisis. When the power went out Gas stations are out of Gas and being ready when the wife and kids need Light and water. Share Ideas and Project both solar and wind to keep us in good shape when these events Happen.
DavidLs
I have been in solar for about 10 years now. After the 2021 Grid failure. I have learned the Mav I believe fits a place to be ready when it happens again. Currently The Mav Hybrid seem to be able to fit for inverter power up to 2K. when the need is a must for H20. So if you have experience with Charge controllers/ Inverters and Panels lets here it
DavidLs
DavidLs
Well it is five in the AM So I kick off with H20 and If you Have a Mav. I will go to an event in a Remote area where there is no power. Water is a Basic Need.Lets say camping with access to a lake or streem .I Believe the Hybrid fits the SHTF well. With the exception of a EMP ( which you and i both may get one day). There is a 12 Volt Screw type well pump That can pump h20 at a decent rate. I have seen the two panel tonnage/Bed cover a fellow Mav owner made. Two Panels to a Charge Controller hooked up to the Mav /Hybrid or Eco either should work then hooked up from the Charge Controller to The 12 Volt Battery jump/recharge terminal. I do recommend a PMW CC as they de-sulfate by nature and are super inexpensive. Now as I understand it the Mavs 400 watt inverter isnt bad so on a minimalist small TV Low power tools ect you would be ok. If you keep That and Water in 12 volt you should be fine. The two Large panels should handle all of it with no battery drain. Just keep everything on the 12 volt side.. The wire run is going to be tricky,
972
